Einleitung
Hier wird der Austausch der Wärmeleitpaste oder des Kühlkörpers gezeigt.
  • Bevor du anfängst, fahre dein Gerät herunter. Schließe das Display und lege es umgekehrt auf eine weiche Oberfläche.
  • Entferne die folgenden zehn Schrauben:
    • Zwei 9 mm Pentalobe P5 Schrauben
    • Acht 2,6 mm Pentalobe P5 Schrauben
  • Der Spezialschraubenzieher, der zum Entfernen der zehn 5-Punkt Pentalobe Schrauben benötigt wird, ist hier erhältlich.
These pentalobe screw sizes can't possibly be right - not even close. Should they perhaps be 0,8 mm and 1,2 mm?
Rulle Boer - Antwort
The screw sizes refer to the length of the shaft, not the diameter of the head or socket. P5 is the standard pentalobe size for all these screws, regardless of length.
I agree that the notation is a little confusing. I think it's because, with standard sized hardware like for your house, you have shaft diameter (say 1/8" or 3mm) and shaft length (say 3" or 7.5cm). So we're programmed to think of small numbers like that as diameter. But in this case, they're length.
budpegasus - Antwort
Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
allison - Antwort
Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
bwgvanderveer - Antwort
I thought I could replace my 256 Gb SSD with 512? regards
ola m - Antwort
Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
andrew - Antwort
It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
Larry Smith - Antwort
tell a model that was not inferior to the speed of the one in the laptop.
Thank you
ilyabuhov - Antwort
Do i need to order tools separately to replace the battery i just ordered?
anne uhlir - Antwort
im looking for a Logic Board for a
Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
Any help is appreciated.
Jamie Comstock - Antwort
Löse das hintere Gehäuse vom Air, indem du mit den Fingerspitzen zwischen Display und Gehäuse gehst und es nach oben ziehst.
  • Löse das hintere Gehäuse vom Air, indem du mit den Fingerspitzen zwischen Display und Gehäuse gehst und es nach oben ziehst.
  • Entferne das hintere Gehäuse und lege es beiseite.
There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
Jeannie Crowley - Antwort
When closing this back up make sure that the antenna cable is tucked away neatly
Gabriel - Antwort
Als Vorsichtsmaßnahme gegen versehentliches Entladen oder einen Elektroschock, trenne die Akkusteckverbindung vom Logic Board. Nimm die durchsichtige Abziehlasche aus Kunststoff, die an der Akkusteckverbindung befestigt ist, und ziehe sie in Richtung der Vorderseite des Airs, um den Akku von dem Logic Board zu trennen.
  • Als Vorsichtsmaßnahme gegen versehentliches Entladen oder einen Elektroschock, trenne die Akkusteckverbindung vom Logic Board.
  • Nimm die durchsichtige Abziehlasche aus Kunststoff, die an der Akkusteckverbindung befestigt ist, und ziehe sie in Richtung der Vorderseite des Airs, um den Akku von dem Logic Board zu trennen.
  • Achte darauf, die Steckverbindung horizontal in Richtung des Akkus zu ziehen und nicht gerade nach oben vom Air weg, da andernfalls die Fassung auf dem Logic Board Schaden nehmen kann.
The clear plastic tab is missing on mine. Whoever worked on my laptop before me seems to have ripped it off. Now what?
mjmorawski - Antwort
Heble mit dem flache Ende eines Spudgers den Stecker des I/O Blendenkabels aus seiner Fassung auf der I/O Blende.
  • Heble mit dem flache Ende eines Spudgers den Stecker des I/O Blendenkabels aus seiner Fassung auf der I/O Blende.
Be really careful when reconnecting the I/O board cable connector. The deep connector has a tendency to bend the pins with very little force applied. If this is the case, check to see if the gold pins are bent down, you may only see one row of gold pins vertically, or none.
They can be lifted with a flat head screwdriver bit. Gently slide the bit under the pins, this may need a small amount of pressure depending on how far they are bent down. Lever the pins back to the vertical position.
I found attempting to insert this connector was easier while holding the MacBook on a slight angle to see down the pins as I aligned the connector.
Another way to tell if the I/O connector cable is in place correctly is to run an Apple Hardware Test. Hold down the letter D while booting the mac and follow the prompts. If no issues found, you're all good.
A common error for a misconnected I/O Connector is 4SNS/1/C0000008:TS0P--124. This means the system cannot read the palm temperature sensor. Fix the cable and you're good
Ben - Antwort
Löse das I/O Blendenkabel vorsichtig von der Oberseite des Lüfters.
  • Löse das I/O Blendenkabel vorsichtig von der Oberseite des Lüfters.
Kommentar hinzufügen
Der folgende Anschluss hat eine besonders tiefgelegte Fassung. Sei vorsichtig, wenn du ihn ablöst. Während du vorsichtig das I/O Blendenkabel nach oben in Richtung seines Anschlusses auf dem Logic Board ziehst, heble mit dem flachen Ende eines Spudgers abwechselnd auf beiden Seiten des Anschlusses, um ihn nach und nach aus seiner Fassung zu lösen.
  • Der folgende Anschluss hat eine besonders tiefgelegte Fassung. Sei vorsichtig, wenn du ihn ablöst.
  • Während du vorsichtig das I/O Blendenkabel nach oben in Richtung seines Anschlusses auf dem Logic Board ziehst, heble mit dem flachen Ende eines Spudgers abwechselnd auf beiden Seiten des Anschlusses, um ihn nach und nach aus seiner Fassung zu lösen.
  • Entferne das I/O Blendenkabel.
This step can be skipped, not required for removing the fan.
yurkennis - Antwort
Agreed, there is no need to remove this cable.
David Robillard - Antwort
Klappe mit der Spudgerspitze vorsichtig die Halteklappe auf dem ZIF-Sockel des Lüftungskabels hoch.
  • Klappe mit der Spudgerspitze vorsichtig die Halteklappe auf dem ZIF-Sockel des Lüftungskabels hoch.
  • Stelle sicher, dass du an der schwenkbaren Halteklappe hebelst und nicht an der Fassung selbst.
It is not necessary to remove the fan cable.
ezequielaceto - Antwort
It's certainly necessary to remove the fan cable, as you won't be able to remove the fan in Step 10 if you don't!
Goth70 Fuzed - Antwort
If you break the ZIF socket, it could be a bad day.... It happened to me. Not one to throw in the towel, I fashioned a hold-down with a length of paperclip held in place by the nearby screw. So far, it is working like a charm. Hopefully, it continues to work and this helps some other poor soul.
Lester Newsom - Antwort
I also haven't removed the fan cable. No need for this step IMHO. Just let the fan on the side instead of completely remove it.
Trouble putting the cable back in the ZIF socket?
Get some electrical tape and cut it down the the width of the ribbon cable fold over one end to create a pull tab. Now place the tape onto the ribbon to give yourself something to pull either in or out as needed. Then you can peel off the tape.
Don't forget the unlatch the connector first!
Source: Re-connecting fan ribbon cable
Adam Banko - Antwort
Löse die Gummidichtung vom Kleber oben auf dem Lüfter.
  • Löse die Gummidichtung vom Kleber oben auf dem Lüfter.
Entferne die folgenden drei Schrauben, mit denen den Lüfter an der oberen Schale befestigt ist:
  • Entferne die folgenden drei Schrauben, mit denen den Lüfter an der oberen Schale befestigt ist:
    • Eine 3,6 mm T5 Torx Schraube
    • Eine 2,7 mm T5 Torx Schraube
    • Eine 3,6 mm T5 Torx Schraube mit einem kurzen Kopf.
Hebe den Lüfter aus dem oberen Gehäuse heraus und ziehe das Flachbandkabel des Lüfters vorsichtig aus seiner Fassung heraus, wenn du es vom Air entfernst.
  • Hebe den Lüfter aus dem oberen Gehäuse heraus und ziehe das Flachbandkabel des Lüfters vorsichtig aus seiner Fassung heraus, wenn du es vom Air entfernst.
Would like more detail about removing the fan cable. Looks like it just pulls out to the right. I thought I ripped it off.
kennyavis81 - Antwort
On re-installation of fan cable cable no tool required - just wiggle it in from from side/above (side force aided by bend of cable)
Super easy - my first computer repair..hope all is well
paul deacon - Antwort
The ribbon connector held in the socket by a tiny square on top, which enters a square hole in the top of the socket. An xacto blade used to pry the top of the connector gently up will help release the connector.
peteragries - Antwort
This helped me no end, I agree with the people above that it's worth explaining how the ribbon cable is held in and that
it's simple to remove and reinstall. Thank you for a brilliant guide.
leesparey - Antwort
Year, from the top, the ribbon appears to be just the plastic strip. Copper connectors are on the bottom but at first glance it looks like I pulled the connector off the ribbon. Mine pulled straight out away from the connector, no upward angle needed or desired.
Allen - Antwort
Question: Is the ribbon connector a part of the fan, so that the new fan has its own ribbon connector? Apologies if this sounds trivial, but I could not tell from the wording/picture.
jerry bennett - Antwort
Trenne das I/O Board, indem du das Versorgungskabel aus dem Anschluss auf dem Logic Board ziehst.
  • Trenne das I/O Board, indem du das Versorgungskabel aus dem Anschluss auf dem Logic Board ziehst.
  • Ziehe das Kabel parallel zur Oberfläche des Logic Boards in Richtung der rechten Kante des Air.
Ziehe das Kamerakabel parallel zur Oberfläche des I/O Board in Richtung des Scharniers des Air und löse es so aus seinem Anschluss. Hilf mit der Spudgerspitze beim Herausdrücken des Steckers aus dem Anschluss.
  • Ziehe das Kamerakabel parallel zur Oberfläche des I/O Board in Richtung des Scharniers des Air und löse es so aus seinem Anschluss. Hilf mit der Spudgerspitze beim Herausdrücken des Steckers aus dem Anschluss.
  • Hebe dieses Kabel beim Lösen nicht nach oben, sonst könnte der Anschluss aus dem Logic Board herausbrechen.
Do you have to replace the IO board and the Logic Board together? Are they matched in some way, or can I just leave the IO board in place, or put back in the original when swapping the Logic Board?
John Howell - Antwort
Use the corner of the flat edge of a spudger to push alternately on the metal ears to help disconnect the cable.
And when reinstalling, push the metal ears from behind to snap the connector back into the socket
Hebele den Stecker am Kabel zum linken Lautsprecher mit dem flachen Ende des Spudgers hoch und aus seinem Anschluss auf dem I/O Board heraus.
  • Hebele den Stecker am Kabel zum linken Lautsprecher mit dem flachen Ende des Spudgers hoch und aus seinem Anschluss auf dem I/O Board heraus.
  • Hebele unter den Drähten.
Don’t use a spludger!!!!! Use tweezers or a super thin flat head. Spludger is too thick…
Jared Thiel - Antwort
Klappe den Sicherungsbügel am Flachbandkabel zum Mikrofon auf dem I/O Board mit der Spudgerspitze hoch. Entferne das Flachbandkabel zur Lautstärkeregelung mit der Spudgerspitze aus seinem ZIF Anschluss auf dem I/O Board.
  • Klappe den Sicherungsbügel am Flachbandkabel zum Mikrofon auf dem I/O Board mit der Spudgerspitze hoch.
  • Entferne das Flachbandkabel zur Lautstärkeregelung mit der Spudgerspitze aus seinem ZIF Anschluss auf dem I/O Board.
This is throwing me for a loop. It won't fit back in. Are the volume and mic cable the same cable?
david nieto - Antwort
Use the tip of the spudger on the plastic ear at the back of the connector (the ear is on the battery side), to push the connector out of the socket.
This step (14) appears to use two different names for the same cable: microphone ribbon cable and volume button ribbon cable. This is confusing because the photos appear to show only a single cable being disconnected from a ZIF socket.
sjosefw - Antwort
Entferne die einzelne 4,0 mm Torx T5 Schraube, welche das I/O Board am oberen Gehäuse befestigt.
  • Entferne die einzelne 4,0 mm Torx T5 Schraube, welche das I/O Board am oberen Gehäuse befestigt.
Hebe das I/O Board vorsichtig an der Kante nahe des Logic Boards hoch und entferne sie vom oberen Gehäuse.
  • Hebe das I/O Board vorsichtig an der Kante nahe des Logic Boards hoch und entferne sie vom oberen Gehäuse.
Entferne die beiden 4,9 mm Torx T8 Schrauben, welche die Halterung des Antennenkabels auf dem linken Displayscharnier am oberen Gehäuse befestigen.
  • Entferne die beiden 4,9 mm Torx T8 Schrauben, welche die Halterung des Antennenkabels auf dem linken Displayscharnier am oberen Gehäuse befestigen.
Schiebe die Halterung des Antennenkabels aus dem Weg und entferne die 3 mm Torx T5 Schraube, welche das Ende des Kühlkörpers am oberen Gehäuse befestigt.
  • Schiebe die Halterung des Antennenkabels aus dem Weg und entferne die 3 mm Torx T5 Schraube, welche das Ende des Kühlkörpers am oberen Gehäuse befestigt.
Entferne die vier 2,5 mm Torx T5 Schrauben, welche den Kühlkörper am Logic Board befestigen.
  • Entferne die vier 2,5 mm Torx T5 Schrauben, welche den Kühlkörper am Logic Board befestigen.
  • Wenn der Kühlkörper immer noch am Logic Board festklebt, obwohl die fünf Schrauben entfernt sind, dann kannst du ihn vorsichtig mit einem Spudger von den Kontaktflächen der GPU und CPU ablösen.
  • Entferne den Kühlkörper vom Logic Board.
  • Beim Zusammenbau musst du eine neue Schicht Wärmeleitpaste auftragen. Wenn du das zum ersten Mal machst, hilft dir unsere Anleitung dabei.
Diese Bilder zeigen, wie die Gummidichtung am Lüfter beim Zusammenbau wieder eingesetzt werden soll. Achte darauf, dass die Dichtung nicht unter die Ausbuchtung kommt, wo das Ende des Kühlkörpers am oberen Gehäuse festgeschraubt wird. Achte auch darauf, dass die kleine Erhebung, die in die Gummidichtung eingeformt ist, genau in den entsprechenden Einschnitt in der oberen rechten Ecke des Logic Boards passt.
  • Diese Bilder zeigen, wie die Gummidichtung am Lüfter beim Zusammenbau wieder eingesetzt werden soll. Achte darauf, dass die Dichtung nicht unter die Ausbuchtung kommt, wo das Ende des Kühlkörpers am oberen Gehäuse festgeschraubt wird.
  • Achte auch darauf, dass die kleine Erhebung, die in die Gummidichtung eingeformt ist, genau in den entsprechenden Einschnitt in der oberen rechten Ecke des Logic Boards passt.
Abschluss
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
11 weitere Nutzer haben diese Anleitung absolviert.
Besonderer Dank geht an diese Übersetzer:
100%
VauWeh hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Beginne zu übersetzen ›
Andrew Optimus Goldberg
Mitglied seit 17.10.2009
367.875 Reputation
1.264 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
117 Mitglieder
5.743 Anleitungen geschrieben
I just swapped out a snapped heatsink & faulty fan, now the Macbook Air fan is on full within 20 seconds of boot & the mouse is lagging like crazy.
I’ve been assembling & repairing computers for years, so know how to apply thermal paste properly, so I’m wondering if I’ve missed something crucial here. Anybody else had issues after replacing the heatsink?
Matt Black - Antwort
Replaced the 6 year old dried up thermal paste with liquid metal, worked like a charm!
Gabriel - Antwort
Hello Gabriel, did you only replace the thermal paste? Or did you install a new heat sink too? My Macbook Air is overheating and shutting down. It has gotten worse over time. I am wondering if just cleaning and replacing the thermal paste will work? What do you think?
Thank you!
Chip -
On my Air the fans were running a lot, but no overheat shutdowns.
I replaced only the thermal paste and after that that the fans rarely ever turned on.
Statistik anzeigen:
Letzte 24 Stunden: 4
Letzte 7 Tage: 25
Letzte 30 Tage: 91
Insgesamt: 9,237
