Einleitung
Hier wird der Austausch eines defekten Mikrofons gezeigt.
  • Bevor du anfängst, fahre dein Gerät herunter. Schließe das Display und lege es umgekehrt auf eine weiche Oberfläche.
  • Entferne die folgenden zehn Schrauben:
    • Zwei 9 mm Pentalobe P5 Schrauben
    • Acht 2,6 mm Pentalobe P5 Schrauben
  • Der Spezialschraubenzieher, der zum Entfernen der zehn 5-Punkt Pentalobe Schrauben benötigt wird, ist hier erhältlich.
These pentalobe screw sizes can't possibly be right - not even close. Should they perhaps be 0,8 mm and 1,2 mm?
Rulle Boer - Antwort
The screw sizes refer to the length of the shaft, not the diameter of the head or socket. P5 is the standard pentalobe size for all these screws, regardless of length.
I agree that the notation is a little confusing. I think it's because, with standard sized hardware like for your house, you have shaft diameter (say 1/8" or 3mm) and shaft length (say 3" or 7.5cm). So we're programmed to think of small numbers like that as diameter. But in this case, they're length.
budpegasus - Antwort
Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
allison - Antwort
Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
bwgvanderveer - Antwort
I thought I could replace my 256 Gb SSD with 512? regards
ola m - Antwort
Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
andrew - Antwort
It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
Larry Smith - Antwort
tell a model that was not inferior to the speed of the one in the laptop.
Thank you
ilyabuhov - Antwort
Do i need to order tools separately to replace the battery i just ordered?
anne uhlir - Antwort
im looking for a Logic Board for a
Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
Any help is appreciated.
Jamie Comstock - Antwort
Löse das hintere Gehäuse vom Air, indem du mit den Fingerspitzen zwischen Display und Gehäuse gehst und es nach oben ziehst.
  • Löse das hintere Gehäuse vom Air, indem du mit den Fingerspitzen zwischen Display und Gehäuse gehst und es nach oben ziehst.
  • Entferne das hintere Gehäuse und lege es beiseite.
There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
Jeannie Crowley - Antwort
When closing this back up make sure that the antenna cable is tucked away neatly
Gabriel - Antwort
Ziehe die Plastiklasche, die am Stecker des Akkus hängt, in Richtung der vorderen Ecke des MacBooks, um den Akku vom Logic Board zu trennen. Der Stecker darf nicht nach oben gezogen werden, während du ihn vom Anschluss trennst.
  • Ziehe die Plastiklasche, die am Stecker des Akkus hängt, in Richtung der vorderen Ecke des MacBooks, um den Akku vom Logic Board zu trennen.
  • Der Stecker darf nicht nach oben gezogen werden, während du ihn vom Anschluss trennst.
The guide says: "Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board", but the battery model that I was replacing did not have a clear plastic pull tab at all...
The battery model shown in this guide is: A1405
I was installing battery model: A1406
A1406 has the following connector:
Top:
http://www.directupload.net/file/d/4122/...
Bottom:
By looking at the bottom of the new battery I saw how it could be removed. Simply by a gentle upward movement. I very, very carefully nudged it a bit upwards using a screwdriver on the left and right side, as shown here:
It came out fairly easy, luckily!
(And yes, I also cleaned up this MacBook before closing it again. It was a bit hairy in a literal way. Electronics and pets is not the best combination. ;-) )
This was a great guide!
wil - Antwort
I think you may have been reading the wrong guide by mistake.
Looking at the various MacBook Air battery replacement guides, all of the 13" models show the connector depicted in this guide. All of the 11" models (e.g. MacBook Air 11" Mid 2012 Battery Replacement) show a connector like the one in your photos.
shamino -
The 13 inch's tab is a bit more difficult to reinstall than uninstall. Delicate care is needed.
Andrew Ruble - Antwort
I agree with Andrew and Joes. I also found that the trickiest part was to pull the tap back when reinstalling the new battery. A special hint at this point in the guide would be nice.
Alexander Kluge -
This is the tricky part if there is one. Just pull back towards the battery and not up.
Joe Wasser - Antwort
hello there, My macbook air does not recognize a battery connected, anymore.
It looks like I damaged the connectors while trying to connect the battery back, although it does not look damaged. I must say, I tried a little force to squeeze the connector in the middle instead of the edge. May have damaged the connector ?
Once, after this, the MBA recognized my battery when pressed the connectors edge to the pins on the board. However, this did not last long and my MBA does not recognize the battery anymore. Any solutions on how I can fix this ? Please help.
Samy Palaniappan - Antwort
Had the same issue where my Macbook did not recognize the battery on the first try. I opened it back up and re-seated the connector and that fixed the problem. That particular connector does not seem to have a positive engagement. It does not appear to seat all the way down. It’s charging now and I hope it will remain stable and connected as I travel.
Paul Tornatta - Antwort
Entferne die folgenden fünf Schrauben, die den Akku am Gehäuse befestigen:
  • Entferne die folgenden fünf Schrauben, die den Akku am Gehäuse befestigen:
    • Drei 6,3 mm Torx T5 Schrauben
    • Zwei 2,4 mm Torx T5 Schrauben
Les couleurs ne me semblent pas justes.
drixe - Antwort
The screw heads are made of a soft butter like chinese metal and will easily get f*cked up. take care when reinstalling to not mess them up.
John Hamilton - Antwort
les couleur sont justes; die rot markierten Schrauben oben und mitte sind länger als die unteren.
I had used the P5 driver there, too (just gently put the bit into the screws and see that’ll fit.
jmhoraze - Antwort
Achte darauf, den Akku nicht zu quetschen und die vier Polymer-Zellen möglichst nicht zu berühren.
  • Achte darauf, den Akku nicht zu quetschen und die vier Polymer-Zellen möglichst nicht zu berühren.
  • Hebe den Akku von der Seite des Logic Boards aus an und entferne ihn vorsichtig aus dem Gehäuse.
Quick note about the replacement battery, if you bought from iFixit and the battery sections have a thin film over them, peel them off. They're to protect the battery during transit, and if you leave them on they might cause heating issues.
Here is a link to my question about it: Replacement battery has thin film on each section do I need to remove? plus, I just got an email from iFixit customer support that it needs to be removed.
dpchoung - Antwort
thank you for the help! I installed the proper batt properly following the advice from here;-) Mahalo from Hawaii-
zzzikaikazzz - Antwort
Does replacement battery for Macbook Air 13" Mid 2012 works with Mac OS Sierra 10.12.3 and up?
Benny Forsberg - Antwort
I installed the battery (OEM Apple) for the Mac Air 2013 throygh 2015:
1. the battery for the Mac Air 2012 throygh 2015 was stated to may have compatibility problems;
2. lesser price;
no problems with macOS Sierra.
jmhoraze - Antwort
Replaced it in no time! Thank you and cheers from Slovenia (that’s the one who beat you in hockey few days ago
Mark Ogner - Antwort
Hebele den Stecker am Kabel zum linken Lautsprecher mit dem flachen Ende des Spudgers hoch und aus seinem Anschluss auf dem I/O Board.
  • Hebele den Stecker am Kabel zum linken Lautsprecher mit dem flachen Ende des Spudgers hoch und aus seinem Anschluss auf dem I/O Board.
  • Hebele unter den Drähten.
Kommentar hinzufügen
Fädle das Kabel zum linken Lautsprecher aus der Halteklammer auf dem I/O Board.
  • Fädle das Kabel zum linken Lautsprecher aus der Halteklammer auf dem I/O Board.
This photograph does not match the model. The microphone has a flat ribbon cable, not a round one.
Goth70 Fuzed - Antwort
Also, the wire has no retaining clip in this model.
Löse den linken Lautsprecher mit dem flachen Ende des Spudgers aus der Klebeverbindung zum oberen Gehäuse. Entferne den linken Lautsprecher aus dem oberen Gehäuse. Entferne den linken Lautsprecher aus dem oberen Gehäuse.
  • Löse den linken Lautsprecher mit dem flachen Ende des Spudgers aus der Klebeverbindung zum oberen Gehäuse.
  • Entferne den linken Lautsprecher aus dem oberen Gehäuse.
Hebele den Mikrofonstecker mit der Kante des Spudgers hoch und aus dem Anschluss auf dem I/O Board.
  • Hebele den Mikrofonstecker mit der Kante des Spudgers hoch und aus dem Anschluss auf dem I/O Board.
In my own MacBook Air 13" mid-2012 A1466, the microphone appears like that of the part offered for sale at the top of the page, not this image.
In this model, the the I/O board cable must also be removed to gain access to the microphone connector. See the upper case replacement guide for removing this part.
Hebele das Mikrofon mit der Spudgerspitze aus der Klebeverbindung zur linken Seite des oberen Gehäuses. Entferne das Mikrofon vom oberen Gehäuse.
  • Hebele das Mikrofon mit der Spudgerspitze aus der Klebeverbindung zur linken Seite des oberen Gehäuses.
  • Entferne das Mikrofon vom oberen Gehäuse.
Abschluss
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
5 weitere Nutzer haben diese Anleitung absolviert.
Besonderer Dank geht an diese Übersetzer:
100%
VauWeh hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Beginne zu übersetzen ›
Andrew Optimus Goldberg
Mitglied seit 17.10.2009
367.975 Reputation
1.264 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
117 Mitglieder
5.744 Anleitungen geschrieben
There is a not 2012 MBA entrails on the photos. Maybe a newer MBA (double mic).
Surgie - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 38
Insgesamt: 3,345
