Was du brauchst
Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
Desolder the battery connections from the motherboard. Learn how to solder components here!
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
Use ESD safe tweezers to remove the gold ribbon cable.
This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
You can now access the parts and pieces on the bottom of, and below the motherboard.
Locate the four main soldering points marked in red.
Be aware of the five additional soldered pins marked by the blue arrow.
Begin to desolder the points pointed out in the last step.
Use the soldering wick to help remove the solder.
3 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
I want to know that what I have to do if want to replace the lithium battery with usb direct powered device.
