Einleitung
Use this guide to replace the charging board in your Motorola Moto E4 (XT1762).
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
Insert a fingernail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover.
Move to the bottom left corner to pry the phone out of the back cover.
Use a fingernail or spudger to pry at the notch at the bottom end of the battery.
Lever the battery out of its recess and remove it.
Insert an opening pick between the loudspeaker and the frame to pry it up by twisting the opening pick.
Remove the loudspeaker unit.
Use the edge of a spudger to pry up and disconnect the interconnect flex cable.
Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
Pry under the bottom end of the charging board and lift it upwards.
Remove the charging board.
Before reassembly check your new part for any components that might need to be transferred from the old one (e.g. microphone rubber gasket).
3 weitere Nutzer:innen haben diese Anleitung absolviert.
