Einleitung
Follow this guide to remove and replace the front-facing camera module for the Moto E4 Plus. You will have to remove the motherboard in order to access the camera module.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
Insert the edge of the spudger into the notch on the bottom right corner of the phone.
Twist the spudger to start releasing the back cover from the phone.
Slide the spudger along the bottom edge to separate the back cover from the phone.
Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
Twist the spudger to release the plastic clip.
Repeat the process for the clip near the top right corner of the phone.
Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
Remove the plastic midframe.
Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
Use the point of a spudger to pry up and disconnect the display cable from its motherboard socket, near the bottom left corner of the motherboard.
Use the point of a spudger to pry up and disconnect the antenna cable from its motherboard socket.
Use the point of a spudger to pry up and disconnect the interconnect cable from its motherboard socket.
Remove the two black 3.2 mm long T3 screws securing the motherboard.
Grasp the motherboard by the top corners and lift it out of the phone.
Remove the motherboard.
Use the point of a spudger to pry up and disconnect the front-facing camera from its motherboard socket.
Flip the motherboard over.
Remove the front-facing camera.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto E4 Plus Answers community for help.
