Zum Hauptinhalt wechseln
Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement
Was du brauchst
  1. Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement, Top Cover: Schritt 1, Bild 1 von 3 Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement, Top Cover: Schritt 1, Bild 2 von 3 Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement, Top Cover: Schritt 1, Bild 3 von 3
    • Position the air fryer so that the front is facing you and the top is accessible.
    • Using opening picks and a metal spudger, pry open the silver ring on the front, right corner.
    • Place an opening pick on the left side of the corner to hold the ring away from the cover.
    • Slide the metal spudger underneath the silver ring. When you find a notch, place the metal spudger next to the notch and pry up to release it.
    • This process requires a significant amount of force to be applied to the silver ring and top cover of the air fryer. It may result in damage to both tools and the air fryer cover.
  2. Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 2, Bild 1 von 1
    • Using a metal spudger, pry open the plastic top cover by inserting into the slots and pushing up on the tabs.
    • There are three openings on the front, one on each side, and four on the back of the unit.
    • The metal spudger may scratch or damage the cover if care is not taken.
  3. Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement, Outer Casing: Schritt 3, Bild 1 von 1
    • Rotate the air fryer so that the back of the air fryer is facing down and the base is facing you.
  4. Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 4, Bild 1 von 3 Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 4, Bild 2 von 3 Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 4, Bild 3 von 3
    • Remove the ten 15 mm screws from the bottom of the air fryer using a Phillips #3 screwdriver.
    • Remove the power cord cover.
    • Remove the two 16.7 mm power cord bracket screws using a Phillips #1 screwdriver.
  5. Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 5, Bild 1 von 1
    • Rotate the air fryer so that the rear fan vents are accessible.
  6. Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 6, Bild 1 von 2 Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 11.1 mm screws from each vent using a Phillips #1 screwdriver.
    • Remove both vents.
  7. Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 7, Bild 1 von 3 Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 7, Bild 2 von 3 Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 7, Bild 3 von 3
    • Carefully pull the outer casing up from the back.
    • Disconnect the front display cable from the motherboard.
    • Fully remove the outer casing.
  8. Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement, Fan Mounting Bracket Gasket: Schritt 8, Bild 1 von 1
    • Rotate the air fryer so that the front is facing you and the top is accessible.
  9. Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 9, Bild 1 von 2 Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 9, Bild 2 von 2
    • Remove the two 43.9 mm fan motor bracket screws using a Phillips #1 screwdriver.
    • Remove the fan motor bracket.
  10. Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 10, Bild 1 von 2 Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 10, Bild 2 von 2
    • Remove the magnetic motor housing.
    • The housing does not need to be fully disconnected.
  11. Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 11, Bild 1 von 2 Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 11, Bild 2 von 2
    • Remove the three 11.6 mm fan mounting bracket screws using a Phillips #1 screwdriver.
    • Remove the washer and silicone gasket from each bracket arm.
  12. Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 12, Bild 1 von 2 Ninja Foodi DZ401 Fan Mounting Bracket Gasket Replacement: Schritt 12, Bild 2 von 2
    • Gently lift one bracket arm and remove the silicone gasket from underneath.
    • Repeat for each remaining bracket arm.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 68
