Einleitung
Follow this guide to remove and replace a defective earpiece speaker for the OnePlus 3. This requires removing the motherboard in order to access the earpiece. The hardest part of the guide is getting the frame clips free.
Some guide images will show the battery already removed from the phone. You do not need to remove the battery for the earpiece speaker procedure.
Was du brauchst
Insert a SIM eject tool, bit, or straightened paperclip into the hole located between the SIM card slot and the power button.
Press firmly to eject the SIM card tray.
Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
Frame seam: This is where the plastic frame meets the back cover. It is recessed into the back cover. Only pry at this seam.
There are fourteen clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
Place a suction cup near the bottom edge of the display.
Pull on the suction cup with strong steady force.
Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
Continue sliding the opening tool along the long edge, releasing the clips along the way.
With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
Lift the screen up and remove it.
Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
Squeeze along the long edges of the phone to snap the remaining clips into place.
Use the point of a spudger to pry up and disconnect the battery connector from its socket, located above the top right corner of the battery pack.
Bend the connector away from the socket to prevent accidental contact.
Remove the 3 mm Phillips screw securing the cable bracket.
Remove the cable bracket.
Use the point of a spudger to pry up and disconnect the interconnect flex cable from the motherboard, which is located above the battery.
Repeat the process to disconnect the daughterboard flex cable from the motherboard.
Slide the point of a spudger underneath the antenna interconnect cable located at the bottom left corner of the motherboard.
Pry up and disconnect the antenna interconnect cable.
Use the point of a spudger to pry up and disconnect the display connector from its socket on the motherboard.
Remove the seven Phillips screws securing the motherboard to the frame:
Four 3 mm black screws
Three 2.9 mm silver screws
The motherboard is still held in place near the top by clips.
Slide the flat end of a spudger underneath the top left corner of the motherboard.
Twist the spudger and pry up to release the motherboard from its recess.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Squeeze the tweezer tips together and insert the point under one of the earpiece speaker clips.
Pull the tweezer point up slowly to pry the earpiece speaker out of its recess.
Remove the earpiece speaker.
To reinstall the earpiece speaker:
Place the earpiece speaker into its recess and firmly press it into place with your finger.
Repair didn’t go as planned? Check out our OnePlus 3 Answers community for troubleshooting help.
9 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
Had a bunch of crap / dirt between the outer grid (visible from the front) and the fine piece of cloth. Cleaned it, but this was the reason why I couldn’t hear.
Thank you! Very detailed!
Thank you ! Super detailed and very nice pictures !
Vorsicht an alle Nachahmer: Mein Display ist einfach mehrfach gerissen, während ich versucht habe, es zu lösen. Keine Chance. Das war so fest verankert, dass ich mit keinem der Werkzeuge richtig was erreichen konnte. Dabei wollte ich nur mal die Ohrmuschel reinigen :-(
