Zum Hauptinhalt wechseln
OnePlus 5 Charging Port/Headphone Jack Replacement
Was du brauchst
  1. OnePlus 5 Charging Port/Headphone Jack Replacement, SIM Card Tray: Schritt 1, Bild 1 von 3 OnePlus 5 Charging Port/Headphone Jack Replacement, SIM Card Tray: Schritt 1, Bild 2 von 3 OnePlus 5 Charging Port/Headphone Jack Replacement, SIM Card Tray: Schritt 1, Bild 3 von 3
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
    • Press firmly to eject the tray.
    • During reassembly, be sure to properly orient the SIM tray you you insert it.
  2. OnePlus 5 Charging Port/Headphone Jack Replacement, Back Cover: Schritt 2, Bild 1 von 1
    • Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
  3. OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 3, Bild 1 von 3 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 3, Bild 2 von 3 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 3, Bild 3 von 3
    • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
    • The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
    • There are two different seams between the body and the screen of the phone:
    • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
    • Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
    • There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
  4. OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 4, Bild 1 von 2 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 4, Bild 2 von 2
    • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
    • Place a suction cup near the bottom edge of the display.
    • Pull on the suction cup with strong steady force.
    • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
    • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
  5. OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 5, Bild 1 von 3 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 5, Bild 2 von 3 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 5, Bild 3 von 3
    • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
    • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
  6. OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 6, Bild 1 von 2 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 6, Bild 2 von 2
    • Lever the opening tool to release the first clip from the frame.
  7. OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 7, Bild 1 von 3 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 7, Bild 2 von 3 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 7, Bild 3 von 3
    • Continue sliding the opening tool along the long edge, releasing the clips along the way.
    • The last clip in the top-left corner near the front-facing camera is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
  8. OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 8, Bild 1 von 1
    • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
    • The frame is still connected to the back cover by a long flex cable. Do not remove the back cover.
    • During reassembly, pause here to test your phone's functionality before securing the back cover.
    • To reinstall the back cover:
    • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
    • Squeeze along the long edges of the phone to snap the remaining clips into place.
  9. OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 9, Bild 1 von 3 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 9, Bild 2 von 3 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 9, Bild 3 von 3
    • With all the clips released, flip the phone over so that the display is face-down.
    • Swing the back cover around and rest it on top of the exposed frame.
    • Be careful not to stress the flex cable connecting the back cover and the frame.
  10. OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 10, Bild 1 von 2 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 10, Bild 2 von 2
    • Remove the 2.6 mm Phillips screw holding the cable bracket above the battery in place.
    • Lift up and remove the cable bracket.
    • To reinstall the bracket, position one end into place, and bend the bracket slightly to spring the other end into place.
  11. OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 11, Bild 1 von 2 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 11, Bild 2 von 2
    • Use the point of a spudger to pry up and disconnect the back cover flex cable from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  12. OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 12, Bild 1 von 1
    • Remove the back cover.
  13. OnePlus 5 Charging Port/Headphone Jack Replacement, Charging Port/Headphone Jack: Schritt 13, Bild 1 von 1
    • Remove the four 2.6 mm Phillips screws holding the port assembly to the back cover.
  14. OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 14, Bild 1 von 3 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 14, Bild 2 von 3 OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 14, Bild 3 von 3
    • Slide an opening pick underneath the port assembly's flex cable to loosen it from the back cover.
  15. OnePlus 5 Charging Port/Headphone Jack Replacement: Schritt 15, Bild 1 von 1
    • Remove the charging port/headphone jack.
Abschluss
Repair didn’t go as planned? Check out our OnePlus 5 Answers Community for troubleshooting help.
41 weitere Nutzer:innen haben diese Anleitung absolviert.
Arthur Shi
252.813 Reputation
526 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
25 Kommentare
The screen is a pain to pry up but the guide itself was good and helped me to successfully fix my phone thank you Jose
Christopher Farmer - Antwort
My headphone jack had stopped holding my headphones in place meaning that the headphones would pop out of the jack very easily. Replacing the jack using this guide was a breeze once the screen had been removed which was the most difficult part of the repair.
I did not have a suction cup to help lift the screen which I in retrospect would recommend anyone doing this repair to get.
Thanks Jose! :)
Andrée - Antwort
Great guide, simple repair. A new charging port fixed my connection issues. I used a plastic butter knife to pry the screen, it took some work but wasn’t that hard.
Thanks!
Filip Märling - Antwort
I just attempted to do this with my phone and the bottom two screws in step 2 were T-1 torx where the instructions are claiming a T-2.
Alan - Antwort
I had the same issue, defintely T1 on my phone rather than T2. T1 is not included in the iFixit srewdriver set unfortunately. Other than that, this guide is great, as other people mentioned prying the back of is difficult but doable. After that it’s a breeze.
Scott Marley -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 18
Letzte 30 Tage: 78
Insgesamt: 39,086
