Zum Hauptinhalt wechseln
OnePlus 6 Rear Camera Replacement
Was du brauchst
  1. OnePlus 6 Rear Camera Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
    Frag FixBot
    Kommentar hinzufügen
  2. OnePlus 6 Rear Camera Replacement: Schritt 2, Bild 1 von 2 OnePlus 6 Rear Camera Replacement: Schritt 2, Bild 2 von 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
    Frag FixBot
  3. OnePlus 6 Rear Camera Replacement: Schritt 3, Bild 1 von 2 OnePlus 6 Rear Camera Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
    Frag FixBot
  4. OnePlus 6 Rear Camera Replacement, Battery: Schritt 4, Bild 1 von 2 OnePlus 6 Rear Camera Replacement, Battery: Schritt 4, Bild 2 von 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
    Frag FixBot
  5. OnePlus 6 Rear Camera Replacement, Fingerprint sensor: Schritt 5, Bild 1 von 2 OnePlus 6 Rear Camera Replacement, Fingerprint sensor: Schritt 5, Bild 2 von 2
    • The midframe is made of plastic and located above the battery space.
    • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
    • ATTENTION - Be aware that the 10th screw is actually underneath the round white sticker marked with the green circle at the bottom left. Do not remove the screw next to it marked with the orange circle or you will damage your midframe board.
    • Lift the bottom of the mid frame directly up and remove it from the device.
    Frag FixBot
  6. OnePlus 6 Rear Camera Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Remove the ten screws holding the motherboard using a Phillips #00 screwdriver.
    Frag FixBot
  7. OnePlus 6 Rear Camera Replacement: Schritt 7, Bild 1 von 2 OnePlus 6 Rear Camera Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the small metal tabs near the battery compartment that are holding the motherboard down.
    • Using a fingernail, carefully work under the edge and pry the motherboard up from the phone.
    • The cameras should lift up with the motherboard.
    Frag FixBot
  8. OnePlus 6 Rear Camera Replacement, Rear Camera: Schritt 8, Bild 1 von 2 OnePlus 6 Rear Camera Replacement, Rear Camera: Schritt 8, Bild 2 von 2
    • Lift up on the small tabs connecting the cameras to the motherboard to disconnect them.
    • Push on the lens side of the cameras and remove them from the motherboard.
    Frag FixBot
Abschluss
Clemson, Team 4-3, Hunter Fall 2021 Mitglied von Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 Mitglieder
21 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 50
Insgesamt: 1,728
