Einleitung
If you plan on replacing the buttons in your Parrot Skycontroller 2 then please look at our troubleshooting page to help fix issues. If the buttons will not work or cannot be cleaned, then it is necessary to replace them. To replace the buttons, use this guide.
Before beginning this repair please reference our Battery Replacement Guide to properly disconnect the battery to allow for safe working conditions.
Was du brauchst
Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
Remove the cover by pulling up and out.
Pull the connectors out by gently pushing the tabs and pulling up on the connector.
Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
Remove the seven black 11mm screws using the Torx TR6 screwdriver.
Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
Remove the seven silver 4mm screws from around the edge of the top plate using the Torx TR6 Screwdriver.
