Einleitung
If the camera of your Petcube Play 2 (identified by model number PP2OUS) is malfunctioning, use this guide to replace it.
The Petcube Play 2 comes with a built-in camera that can record and stream videos of your pet to your phone. A defective camera might lead to poor video quality, skipping, or recording failures.
Before using this guide, ensure that there are no connection issues between the Petcube, your Wi-Fi router, and your phone. The Troubleshooting Page covers connection and video quality-related issues and how to address them.
Ensure the Petcube Play 2 is turned off before beginning the replacement process.
Was du brauchst
Flip over the Petcube so the rubber bottom faces you.
Use an iFixit opening pick to pull up the rubber layer and expose the screws underneath.
Use a Phillips #1 screwdriver to remove the four 3.5 mm screws under the rubber cover.
Slide off the two covers, starting with the top plastic cover.
Slide out the internal assembly from the aluminum.
Flip the cube onto one of its sides to locate the pull tabs holding the two halves together.
Lift each of the five tabs using an opening tool to separate the two halves of the Petcube 2.
Use the size #1 Phillips screwdriver to remove the two 1 mm screws.
Carefully release the three tabs and take out the motherboard.
Use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
Use the Phillips #00 screwdriver to remove the three 1 mm screws securing the camera to the motherboard.
Remove the camera from the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
