Einleitung
If the motherboard of your Petcube Play 2 (identified by the model number PP2OUS) is damaged or is faulty, use this guide to replace it.
A motherboard is a core component of electronic systems. They hold many of the important electronic parts of a system and allow them to communicate with each other. A faulty or damaged motherboard in a Petcube Play 2 will lead to Wi-Fi connection issues, the device turning off unexpectedly, or the device refusing to turn on.
Before beginning, ensure that these issues are not caused by other circumstances detailed in the Troubleshooting Page. Also ensure that the device is turned off and unplugged.
Was du brauchst
Flip over the Petcube so the rubber bottom faces you.
Use an iFixit opening pick to pull up the rubber layer and expose the screws underneath.
Use a Phillips #1 screwdriver to remove the four 3.5 mm screws under the rubber cover.
Slide off the two covers, starting with the top plastic cover.
Slide out the internal assembly from the aluminum.
Flip the cube onto one of its sides to locate the pull tabs holding the two halves together.
Lift each of the five tabs using an opening tool to separate the two halves of the Petcube 2.
Use the size #1 Phillips screwdriver to remove the two 1 mm screws.
Carefully release the three tabs and take out the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
