Zum Hauptinhalt wechseln
Razer Blade Stealth 2017 Battery Replacement
Was du brauchst
  1. Razer Blade Stealth 2017 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Razer Blade Stealth 2017 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Battery Replacement: Schritt 3, Bild 1 von 2 Razer Blade Stealth 2017 Battery Replacement: Schritt 3, Bild 2 von 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Battery Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Battery Replacement: Schritt 5, Bild 1 von 2 Razer Blade Stealth 2017 Battery Replacement: Schritt 5, Bild 2 von 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
14 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S11-G3, Regan Fall 2019 Mitglied von Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
ive done everything correctly and laptop boots up but now I have no battery percentage information. any solutions on how to fix?
fdf - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 25
Letzte 30 Tage: 113
Insgesamt: 16,533
