Zum Hauptinhalt wechseln
Razer Blade Stealth 2017 Battery Replacement
Was du brauchst
  1. Razer Blade Stealth 2017 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Razer Blade Stealth 2017 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Battery Replacement: Schritt 3, Bild 1 von 2 Razer Blade Stealth 2017 Battery Replacement: Schritt 3, Bild 2 von 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Battery Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Battery Replacement: Schritt 5, Bild 1 von 2 Razer Blade Stealth 2017 Battery Replacement: Schritt 5, Bild 2 von 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
16 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S11-G3, Regan Fall 2019 Mitglied von Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
4 Mitglieder
7 Anleitungen geschrieben
5 Kommentare zur Anleitung
ive done everything correctly and laptop boots up but now I have no battery percentage information. any solutions on how to fix?
fdf - Antwort
Where did you get the replacement battery? The replacement we purchased for two Razer units about a year ago worked fine, but a replacement battery purchased online about a month and a half ago from Amazon is showing the same issue. Essentially, it's not detected by the operating system at all, or only very rarely. Looks like a bad batch of batteries from wherever these sellers are getting their supply.
DST - Antwort
The laptop powers on but when plugged in it starts then stops charging
Boogie - Antwort
Hey Boogie!
I am also having same issue, have you manage to solve it?
Andrea Torrico -
My laptop powers on, charges, holds the charge, shows battery percentage on screen, BUT now the white charge light does not turn on. Anyone know how to fix this or if this is a common issue with this part?
I tried all the solutions from Google which said to:
1. Verify Power Adapter and Connection:
- I checked all physical connections and the charger I use is an new official one from Razer that is barely about a year old.
2. Check Battery and Cable Connections:
Opened the laptop again to make sure all the connections were good.
3. Software and Driver Checks:
Battery Report: Created one and every thing looks like it checks out the new batttery read 42% when I installed it and after the calibration from iFixit everything look good.
Driver Updates: My Laptop says it is up- to-date with the last windows 10 update.
BIOS Update: Didn’t really do this one on the count of that I am scared that I might break my laptop, but if it gets updated when Windows is updated then it should be fine.
4. Power Discharge Procedure
Unplugged the battery from the motherboard, held power for 1 min., plugged laptop directly into charger without battery, powered on no issues, and then reassembled it.
Again this is not a deal breaker for me the laptop works just fine, but would just like to know if there is a fix.
Thank you iFixit for the tools and parts and thank you iFixit community for any help.
Eric Estrada - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 21
Letzte 30 Tage: 96
Insgesamt: 18,801
