Diese Anleitung enthält neuere Änderungen. Wechsel zur neuesten unüberprüften Version.
Einleitung
Use this guide to replace the fingerprint sensor on your Samsung Galaxy S8.
This guide involves removing the rear glass cover, you will need replacement adhesive to reattach the back cover to the phone.
Was du brauchst
Heat the iOpener for thirty seconds.
Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Heat an iOpener and apply it to a long edge of the S8 for about 2 minutes.
In the following steps you will be cutting through the adhesive around the edge of the rear glass panel.
The adhesive on the rear case is laid out as seen in the first image.
The prying pattern as seen from the outside of the phone is as follows:
Thick portions of adhesive
Thin areas of adhesive
Avoid prying here, to protect the fingerprint sensor.
Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
Lift on the suction cup, and insert an opening pick under the rear glass.
Once you have the tool firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
Use the opening picks to slice through any remaining adhesive and open the phone slightly.
Remove the glass from the phone.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
If you're installing a new rear glass panel, you'll also need to transfer the fingerprint sensor to your new rear glass panel as follows:
Reheat an iOpener and apply it to the fingerprint sensor mounted to the rear glass.
Push the fingerprint sensor off of its adhesive from the outside of the glass.
If the sensor is stubborn, gently slide an opening pick under the plastic backing to loosen the adhesive before pushing.
After removing the old adhesive, clean the edges of the fingerprint sensor with high concentration isopropyl alcohol (at least 90%), then apply the new adhesive.
After reapplying adhesive, follow these instructions in reverse order to reassemble your device.
After you've completed the repair, follow this guide to test your repair.
23 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
Can I replace the Galaxy S8 finger print sensor or would it void the Knox security on the phone? Thanks!
how come the part shown has a straight flex but the button being removed has a semi s shape
Why is the part for $19.99 shown with a straight flex but the part being removed has an S shaped flex. Are they interchangeable?
Hi Frank! Our part happens to have a differently shaped cable, but is completely compatible with the Galaxy S8. Because we can’t get parts straight from Samsung, there are sometimes minor differences that don’t affect the function of the part.
