Einleitung
Use this guide to replace the motherboard in a Samsung Galaxy Watch.
Was du brauchst
Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
Use an opening tool to get between the back cover and the metal housing of the watch.
Carefully pry the plastic back cover open.
Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
Use a spudger to disconnect the display flex cable from the motherboard.
Use a pair of tweezers to gently peel both button cables from the plastic frame.
Insert a spudger into the small gap underneath the motherboard where the cutout in the plastic frame is.
Lift the motherboard by twisting the spudger.
Slide the motherboard out from under the plastic tab.
If possible, turn on your device and test your repair before resealing.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
Anyone know where to purchase a Galaxy Watch mother board?
What is the part number, or where can you get the motherboard?
Where can the motherboard be purchased from for Galaxy Watch ?
I got a motherboard on ebay. Including import duties it was something like 90$. Shipped to Denmark.
Definitely cheaper than repair shop and absolutely more fun! :)
