Einleitung
This guide shows how to remove and replace a broken icemaker assembly in your Samsung RF28T5001SR refrigerator.
This model's icemaker resides in the freezer compartment. The icemaker uses a twisting mechanism to loosen the ice cubes from the tray. Oftentimes, the plastic tray cracks from repeated operation and the mechanism won't release the ice cubes anymore.
Was du brauchst
Unplug your refrigerator before you begin your repair.
Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
While pressing the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
Remove the freezer drawer.
Push the geared torsion bar until it rests at the very end of the rails.
Align the drawer rails to the refrigerator wall guides.
Close the freezer drawer until the rails lock back in place.
Use a Phillips screwdriver to remove the two 18.5 mm-long screws securing the icemaker assembly to the freezer ceiling.
Grasp the front edge of the icemaker assembly and tilt it downwards.
Repair didn’t go as planned? Ask our Answers community for help.
