Einleitung
If your ice bucket (aka ice tray, ice bin, or ice tub) is cracked, use this guide to replace it.
The ice bucket stores ice cubes for dispensing. The bucket assembly often includes an auger and a dispenser flap. It does not include the auger motor or dispenser actuator. If your fridge doesn't dispense ice, you may need to defrost this bucket.
This guide will work for with many refrigerator models. The photos in this guide are from a Samsung RF28R7201SG refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Was du brauchst
Open both French doors for the refrigerator compartment.
Pull the ice bucket straight out of its housing and remove it.
Repair didn’t go as planned? Ask our Answers Community for help.
Eine weitere Person hat diese Anleitung absolviert.
4 Kommentare zur Anleitung
Ice dispenser cracked.. Samsung french door refrigerator...can it be fixed
Used Testor’s non toxic model cement after cleaning the crack with alcohol.
Can't get the ice bucket to line up with the auger b
Gear
Can't get the ice bucket auger gear to line up with the motor arm.wont close.
