Zum Hauptinhalt wechseln
Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker)
Was du brauchst
  1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unplug your refrigerator: Schritt 1, Bild 1 von 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: Schritt 2, Bild 1 von 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: Schritt 2, Bild 2 von 2
    • Slide the freezer drawer fully open.
  3. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: Schritt 3, Bild 1 von 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: Schritt 3, Bild 2 von 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: Schritt 3, Bild 3 von 3
    • Lift and remove all the freezer bins from the drawer.
    • You may need to open the refrigerator doors in order to remove the large bin.
  4. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: Schritt 4, Bild 1 von 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: Schritt 4, Bild 2 von 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: Schritt 4, Bild 3 von 3
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): Schritt 5, Bild 1 von 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): Schritt 5, Bild 2 von 2
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  6. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: Schritt 6, Bild 1 von 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: Schritt 6, Bild 2 von 2
    • Use a Phillips screwdriver to remove the screws securing the icemaker assembly to the freezer ceiling.
  7. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: Schritt 7, Bild 1 von 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: Schritt 7, Bild 2 von 2
    • Grasp the front edge of the icemaker assembly and tilt it downwards.
    • Don't try to remove the icemaker yet, as it's still connected by a few wires.
  8. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): Schritt 8, Bild 1 von 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): Schritt 8, Bild 2 von 2
    • Use your fingers to guide the wire harness out of the icemaker assembly.
  9. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): Schritt 9, Bild 1 von 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): Schritt 9, Bild 2 von 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): Schritt 9, Bild 3 von 3
    • Squeeze the icemaker cable connector and pull to disconnect it.
  10. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): Schritt 10, Bild 1 von 1
    • Remove the icemaker assembly.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
2 weitere Personen haben diese Anleitung absolviert.
Arthur Shi
282.913 Reputation
587 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
119 Mitglieder
19.521 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 23
Letzte 30 Tage: 81
Insgesamt: 839
