Zum Hauptinhalt wechseln
Screen Replacement
Was du brauchst
    1. Screen Replacement, Back Cover: Schritt 1, Bild 1 von 3 Screen Replacement, Back Cover: Schritt 1, Bild 2 von 3 Screen Replacement, Back Cover: Schritt 1, Bild 3 von 3
      • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
      • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
      • Avoid prying on the buttons, as they are easily damaged.
      Frag FixBot
      Kommentar hinzufügen
    2. Screen Replacement: Schritt 2, Bild 1 von 1
      • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
      Frag FixBot
    1. Screen Replacement, Battery: Schritt 3, Bild 1 von 1
      • Remove masking tape from the battery.
      Frag FixBot
    2. Screen Replacement: Schritt 4, Bild 1 von 3 Screen Replacement: Schritt 4, Bild 2 von 3 Screen Replacement: Schritt 4, Bild 3 von 3
      • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
      • Handle the battery with care to avoid damaging it.
      Frag FixBot
    3. Screen Replacement: Schritt 5, Bild 1 von 3 Screen Replacement: Schritt 5, Bild 2 von 3 Screen Replacement: Schritt 5, Bild 3 von 3
      Frag FixBot
    1. Screen Replacement, Motherboard: Schritt 6, Bild 1 von 3 Screen Replacement, Motherboard: Schritt 6, Bild 2 von 3 Screen Replacement, Motherboard: Schritt 6, Bild 3 von 3
      • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
      • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
      Frag FixBot
    2. Screen Replacement: Schritt 7, Bild 1 von 1
      • Use the nut driver and J00 bit to remove the three 4 mm screws.
      Frag FixBot
    3. Screen Replacement: Schritt 8, Bild 1 von 3 Screen Replacement: Schritt 8, Bild 2 von 3 Screen Replacement: Schritt 8, Bild 3 von 3
      • Peel back metal tape that is hiding the auxiliary port wires.
      • Remove tape that is holding the speaker wires in place.
      • Lift up on the motherboard to release it from the tablet.
      Frag FixBot
    1. Screen Replacement, Screen: Schritt 9, Bild 1 von 1
      • Use the nut driver and the J0 bit to unscrew the four 4 mm screws
      Frag FixBot
    2. Screen Replacement: Schritt 10, Bild 1 von 2 Screen Replacement: Schritt 10, Bild 2 von 2
      • If your are replacing a broken screen be careful when handling broken glass.
      • Remove the screen from the front cover of the device. At this point there should be no other component holding the screen down.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Baylor, Team 4-1, Williams Fall 2016 Mitglied von Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
4 Mitglieder
35 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 90
Insgesamt: 3,651
