Zum Hauptinhalt wechseln
Scuf Instinct Pro Batteries Replacement
Was du brauchst
  1. Scuf Instinct Pro Batteries Replacement, Prepare your controller for disassembly: Schritt 1, Bild 1 von 1
    • Unplug all cables from your controller before starting.
    • Completely power off your controller.
    Frag FixBot
  2. Scuf Instinct Pro Batteries Replacement, Remove the battery cover: Schritt 2, Bild 1 von 2 Scuf Instinct Pro Batteries Replacement, Remove the battery cover: Schritt 2, Bild 2 von 2
    • Weak magnets and two clips along the bottom edge secure the battery cover to the controller.
    • Slide the battery cover away from the controller to remove it.
    Frag FixBot
  3. Scuf Instinct Pro Batteries Replacement, Remove the batteries: Schritt 3, Bild 1 von 3 Scuf Instinct Pro Batteries Replacement, Remove the batteries: Schritt 3, Bild 2 von 3 Scuf Instinct Pro Batteries Replacement, Remove the batteries: Schritt 3, Bild 3 von 3
    • If your batteries are starting to corrode, clean the contacts and replace the batteries.
    • Use your fingers to remove the batteries.
    • During reassembly, insert the batteries so their positive (+) and negative () ends match up with the markings on the battery contacts.
    Frag FixBot
Abschluss
Spencer Day
188.903 Reputation
1.187 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.805 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 49
Insgesamt: 1,853
