Zum Hauptinhalt wechseln
Vtech Innotab 3 Microphone Replacement
Was du brauchst
    1. Vtech Innotab 3 Microphone Replacement, Rear Panel: Schritt 1, Bild 1 von 3 Vtech Innotab 3 Microphone Replacement, Rear Panel: Schritt 1, Bild 2 von 3 Vtech Innotab 3 Microphone Replacement, Rear Panel: Schritt 1, Bild 3 von 3
      • Slide the battery compartment door lock down.
      • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
      • Carefully remove the batteries from the battery compartment.
      • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
      Frag FixBot
      Kommentar hinzufügen
    2. Vtech Innotab 3 Microphone Replacement: Schritt 2, Bild 1 von 1
      • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
      Frag FixBot
    3. Vtech Innotab 3 Microphone Replacement: Schritt 3, Bild 1 von 3 Vtech Innotab 3 Microphone Replacement: Schritt 3, Bild 2 von 3 Vtech Innotab 3 Microphone Replacement: Schritt 3, Bild 3 von 3
      • There are three hidden screws on the back of the device, two at the top and one near the bottom.
      • Using a nylon or metal spudger, remove the three caps that hide the screws.
      • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
      Frag FixBot
    4. Vtech Innotab 3 Microphone Replacement: Schritt 4, Bild 1 von 1
      • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
      Frag FixBot
    1. Vtech Innotab 3 Microphone Replacement, Microphone: Schritt 5, Bild 1 von 3 Vtech Innotab 3 Microphone Replacement, Microphone: Schritt 5, Bild 2 von 3 Vtech Innotab 3 Microphone Replacement, Microphone: Schritt 5, Bild 3 von 3
      • Remove the four 7.6 mm screws using a PH00 screwdriver.
      • Lift up the circuit board from the device.
      Frag FixBot
    2. Vtech Innotab 3 Microphone Replacement: Schritt 6, Bild 1 von 3 Vtech Innotab 3 Microphone Replacement: Schritt 6, Bild 2 von 3 Vtech Innotab 3 Microphone Replacement: Schritt 6, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      • To replace the microphone, desolder the two connections that connect the speaker to the device.
      • Use tweezers to keep the microphone steady as you desolder the connections.
      • This is a tricky step. Refer to this guide to learn how to solder: How To Solder and Desolder Connections
      Frag FixBot
Abschluss
Colorado Springs, Team 5-4, Panko Spring 2015 Mitglied von Colorado Springs, Team 5-4, Panko Spring 2015
UCCS-PANKO-S15S5G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 651
