Zum Hauptinhalt wechseln
Xbox Series X|S Controller (Model 1914) Top Housing Replacement
Was du brauchst
  1. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the battery cover: Schritt 1, Bild 1 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the battery cover: Schritt 1, Bild 2 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the battery cover: Schritt 1, Bild 3 von 3
    • Use your fingers to slide up and remove the battery cover.
  2. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the batteries: Schritt 2, Bild 1 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the batteries: Schritt 2, Bild 2 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the batteries: Schritt 2, Bild 3 von 3
    • Remove the batteries.
    • When re-inserting the batteries, make sure to position them correctly, with their positive (+) and negative (–) ends matching up with the markings on the controller’s battery contacts. If your batteries are starting to corrode, replace them with new batteries.
  3. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: Schritt 3, Bild 1 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: Schritt 3, Bild 2 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: Schritt 3, Bild 3 von 3
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  4. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the left handle cover clips: Schritt 4, Bild 1 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the left handle cover clips: Schritt 4, Bild 2 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the left handle cover clips: Schritt 4, Bild 3 von 3
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  5. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the left handle cover: Schritt 5, Bild 1 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the left handle cover: Schritt 5, Bild 2 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the left handle cover: Schritt 5, Bild 3 von 3
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  6. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: Schritt 6, Bild 1 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: Schritt 6, Bild 2 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: Schritt 6, Bild 3 von 3
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
  7. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the right handle cover clips: Schritt 7, Bild 1 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the right handle cover clips: Schritt 7, Bild 2 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the right handle cover clips: Schritt 7, Bild 3 von 3
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
  8. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the right handle cover: Schritt 8, Bild 1 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the right handle cover: Schritt 8, Bild 2 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the right handle cover: Schritt 8, Bild 3 von 3
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  9. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Reposition the battery compartment sticker: Schritt 9, Bild 1 von 2 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Reposition the battery compartment sticker: Schritt 9, Bild 2 von 2
    • The sticker in the battery compartment covers a housing screw. Peel it back or pierce through it with a screwdriver.
    • Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
  10. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Unfasten the top housing: Schritt 10, Bild 1 von 2 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Unfasten the top housing: Schritt 10, Bild 2 von 2
    • Use a Torx T8 Security screwdriver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
  11. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the top housing: Schritt 11, Bild 1 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the top housing: Schritt 11, Bild 2 von 3 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the top housing: Schritt 11, Bild 3 von 3
    • Lift the top housing straight up to remove it.
Abschluss
Manuel Haeussermann
14.243 Reputation
71 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
142 Mitglieder
16.239 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 35
Letzte 30 Tage: 194
Insgesamt: 1,159
