Zum Hauptinhalt wechseln
Zeki Droid Tablet Front Screen Replacement
Was du brauchst
    1. Zeki Droid Tablet Front Screen Replacement, Back Casing: Schritt 1, Bild 1 von 1
      • Remove the back casing by slowly popping each tab out with a plastic opening tool.
      Frag FixBot
      Kommentar hinzufügen
    2. Zeki Droid Tablet Front Screen Replacement: Schritt 2, Bild 1 von 1
      In diesem Schritt verwendetes Werkzeug:
      • Remove the tapes one by one from the connecting wires with tweezers.
      Frag FixBot
    3. Zeki Droid Tablet Front Screen Replacement: Schritt 3, Bild 1 von 1
      • Remove the black clips from both sides of the casing with a plastic opening tool.
      • The clips should pop off separate from the speakers.
      Frag FixBot
    4. Zeki Droid Tablet Front Screen Replacement: Schritt 4, Bild 1 von 1
      • Remove the speakers from the back casing.
      • Do not tug on the speakers because they are connected to fragile wires.
      Frag FixBot
    5. Zeki Droid Tablet Front Screen Replacement: Schritt 5, Bild 1 von 1
      • Pull the speakers away from the back casing carefullly.
      Frag FixBot
    1. Zeki Droid Tablet Front Screen Replacement, Front Screen: Schritt 6, Bild 1 von 1
      • Detach the motherboard from the framing by removing the four screws using a Phillips #000 screwdriver.
      Frag FixBot
    2. Zeki Droid Tablet Front Screen Replacement: Schritt 7, Bild 1 von 1
      • Lift the camera and flash components from their fittings using tweezers.
      Frag FixBot
    3. Zeki Droid Tablet Front Screen Replacement: Schritt 8, Bild 1 von 1
      • Lift the metal framing to reach the components at the front of the device.
      • Do not pull the framing completely off. There is a ZIF connecter holding it in place.
      Frag FixBot
    4. Zeki Droid Tablet Front Screen Replacement: Schritt 9, Bild 1 von 2 Zeki Droid Tablet Front Screen Replacement: Schritt 9, Bild 2 von 2
      • Push the screen forward to remove.
      Frag FixBot
Abschluss
Kyla
156 Reputation
2 Anleitungen geschrieben
Colorado Springs, Team 2-6, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-6, Panko Spring 2015
UCCS-PANKO-S15S2G6
3 Mitglieder
15 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 568
