Einleitung
This guide walks through the disassembling of a Zojirushi Rice Cooker NP-HMH10 and replacing the internal battery.
If the front panel screen of a Zojirushi Rice Cooker does not show information, most likely the internal battery of the rice cooker is dead (except damage caused by human factors).
In this guide, the soldering iron is necessary, and be sure you have a basic knowledge of soldering or use the tool under the supervision of a person who has experience.
For safety reasons, unplug the device before you begin.
Werkzeuge
Ersatzteile
Flip the device over and remove the four screws on the base using the Phillips #0 screwdriver.
Using a Torx T9 screwdriver remove one screw from the bottom of the rice cooker.
Remove the screws that connect the thick black and orange cables to the heat sink.
Now switch to the fan of the heatsink. Using a tweezer carefully lift the four clips around the fan.
Pull out the fan.
After removing the fan now you can take out the whole heatsink and access the below part.
Above the PCB (Printed Circuit Board) is an isolated-plate. Take it away and unscrew the PCB below it.
Turn the PCB to the other side. Find the soldering point of the battery as in the picture.
