Einleitung
Follow this guide to replace the logic board on a 2020 iMac 27" 5K.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Removing the display on the 2020 iMac Intel 27" Retina 5K Display requires cutting adhesive with a specialized iMac opening tool. After you've completed your repair, you'll need to follow our display adhesive guide to scrape off the old adhesive and replace it with new double-sided adhesive strips.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:iMac Intel 27" Cardboard Service Wedge$4.99
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
Run the tool up along the left side of the display.
Continue wheeling the tool up around the top left corner.
Finish pushing the opening tool to the bottom of the right side of the display.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Set the iMac face-up on a table.
Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
Slide the card toward the center of the display, to cut any remaining adhesive.
Put the card into the corner again and let it stay there to keep the adhesive from resettling.
Insert a second card into the gap between the display and frame in the top left corner.
Gently twist the card, slightly increasing the space between the display and frame.
Slide the plastic card toward the center, again stopping just before the iSight camera.
With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
Begin to lift the top of the display up from the frame.
While holding the display up with one hand, use the other to unplug the display power cable.
Flip up the metal retaining bracket on the display data cable.
Disconnect the display data cable.
Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
Repeat this step with the other adhesive strip and remove it.
Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
Use a Phillips screwdriver to remove the nine 3.2 mm screws securing the support bracket.
You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
Remove the lower support bracket (a.k.a. "chin strap") from the iMac enclosure.
Unplug the left speaker cable by pulling it straight up out of its socket on the logic board.
De-route the cable from the gap between the hard drive and logic board.
Use a spudger to disconnect the power button connector from its socket on the logic board.
Lift the left speaker straight up, until the power button cable is exposed (about 0.5 inches).
Lift the left speaker straight up and remove it from the iMac.
Push from the connector end as you pull from the speaker end to thread the cable under the hard drive's right bracket.
Disconnect the power supply control cable from the power supply.
Remove the following four screws securing the power supply to the rear case (size T8 or T10 depending on the exact model):
Two 23.7 mm Torx screws
Two 7.3 mm Torx screws
Move the power supply board towards the left edge of the case and up to free it from the notch in the logic board.
Depress the tab on the DC power cable connector, then pull it straight out of its socket on the back of the logic board.
Flip the top of the power supply towards you, like opening a mailbox, to reveal the AC inlet cable connector.
Disconnect the AC inlet cable connector.
Gently rock the right speaker slightly to the right, to allow access to its cable's connection on the logic board.
Use a spudger to loosen the right speaker cable's connector from its socket on the logic board.
Pull the connector to the right to remove it from its socket.
Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
Peel the black tape connecting the fan to the exhaust duct back slightly.
Leave the tape in place on the exhaust duct—you only need to expose the joint to free the fan.
Use a T5 Torx screwdriver to remove the two 4 mm screws securing the AirPort/Bluetooth antenna cables.
Use a pair of tweezers or your fingers to disconnect the ribbon cable left of the antenna cables from the logic board.
Use the pointed end of a spudger to disconnect the headphone jack cable connector from its socket on the logic board.
Gently push the cable out of the way.
Use the tip of a spudger to flip open the retaining flap on the microphone ribbon cable ZIF socket.
Use a pair of tweezers to gently pull the microphone ribbon cable straight out of its socket.
Use a T8 Torx screwdriver to remove the two 5.6 mm screws from the top of the heat sink exhaust duct.
Remove the following screws securing the logic board:
Two 23.7 mm T8 screws
One 20.1 mm T25 spacer screw
One 17.6 mm T8 screw
One 7.2 mm T8 screw
Three 7.1 mm T8 screws
One captive T8 screw
Tilt the logic board slightly forward.
Lift the logic board straight up and out of the iMac. Be careful not to snag it on any of the screw posts attached to the inside of the rear case.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
Are these really pictures of a 2020? I don’t think Apple ever sold any of the 2020 units with a rotational hard drive.
Correct, this is not a 2020 27-Inch iMac.
I tested the procedure and found that these iMacs were similar enough that reshooting photos was not necessary. As noted in the introduction, some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Is this the same procedure for replacing the logic board on a Mid-2017 iMac? That page doesn't have a repair guide for logic board replacement.
