Zum Hauptinhalt wechseln
Das Nokia 6303 wurde von Nokia im Mai 2009 auf den Markt gebracht und ist hauptsächlich für Sprachanrufe, Textnachrichten und Musikwiedergabe konzipiert.
resetting security code how
My keypad is locked with security code. I changed the security code. Now I can't open it. Either I forgot what code I entered or I pressed the wrong numbers and I didn't know. Now I can't unlock my phone. What can I do to solve this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 29
4 Kommentare
Tengo un telefono que me enviaron desde inglaterra y vivo en colombia como hago para el codigo de seguridad
von
nokia6303 secruty code
von
I keep receiving phone number. 6303036998032 ? my phone ia a Samsung ?
What is going on?
von
unlock my moile nokia 6303i
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
What's your Mobile model?
Try default codes like 12345,00000.If your mobile is Nokia or Alcatel you easily reset your mobile by using Master Reset code.You can get the code from Unlock-Free.com at free of cost.Here they will generate you reset code within a minute by specifying your mobile model no and IMEI.
Note:They will provide reset codes for some basic Alcatel and Nokia mobile models only.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Thank you you umblocked my password Im so stupid
von
cant find nokia 6303ci !
von
Hi security code for Nokia ta-1402 8 digits
von
Kae, follow these instructions Hope this helps, good luck.
Bewertung 1
3 Kommentare:
Dead link. Was going to accept it, letting you know. I also got a redirect alert from AdGuard in Chrome, now the site will not load in Safari OR Chrome. Normally I'd try and find a working reference but with 2G being doomed globally I'm just going to "solve" this one by accepting @braksa's answer.
Likely blocked by the Mac AdGuard app. Not your fault the ownership changed, but I'm letting you know.
von
@nick 🤣you know it does not matter as long as something worked for the OP. It’s not about accepting but about getting in solved. Best answer is always the right answer 👍
von
@oldturkey03 it either redirects to a dead page or very suspicious links.
von
i forget my nokia 6303ci password ,how to open it?
Bewertung 1
Antwort hinzufügen
Kae wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 43
Insgesamt: 25,301
