Zum Hauptinhalt wechseln
Das Samsung Galaxy S4, Modell i9505, ist mit einer 13 Megapixel Rückkamera und einem 5 Zoll 1080p Display ausgestattet.
526 Fragen Alle anzeigen
GPS fault after Samsung Galaxy S4 Display Assembly Replacement
Hi,
Followed the guide here: Samsung Galaxy S4 Display Einheit ersetzen
Awesome easy!
All went to plan without any issues with the work however the GPS is now not working correctly. I would like to know what parts/cables I should be looking at to check for lose connections etc.
Any ideas...?
Ist dies eine gute Frage?
Bewertung 6
4 Kommentare
I've opened the device up again however no lose connection. Come on guys! For all I know the screens part of the gps and I purchase a DOA part! What parts should I replace if the GPS don't work anymore...
von
Quickest solution I found was selling it on ebay and buying a new Galaxy S5... :) Still I want to know what caused this...
von
FYI: http://allaboutgalaxys4.com/galaxy-s4-on...
Shows you the GPS atenna location.
von
Just check your power saving status. If it is on than just switch off. Than check your gps fix ;)
von
Einen Kommentar hinzufügen
20 Antworten
Hilfreichste Antwort
try to see if you forgat a screw, or if there a lose screw in the phone, i know there is a problem with the screwes in s3..
i have the same problem in s4 and i saw they forgot a screw in the right side of the phone(silver screw). i'm waiting for a new screw.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Update:
it turns out, that the screen was probably defected and influenced gps and wifi, tew weeks after i replaces the screen the thouch stoped working, then they replaced the screen again and the gps and wifi started working perfectly!
von
Brilliant I took my phone apart a half dozen times convinced I missed something. I ordered another replacement and returned the old. Worked perfect GPS and WiFi are both normal. I guess there is something in the assembly for the antenna.
von
In my case the problem was conductive rubber seal on magnesium mid frame that bears motherboard all around. On original screen this seal was very well conductive. On replacement screen (ordered from China Alliexpress) there is nonconductive seal from silicone rubber adhesive.
The solution is to cut original seal very gently. Than cut silicon rubber seal from replacement screen and place original seal in it.
See the difference (replacement part with extracted original seal laying on it):
https://goo.gl/photos/WVab9a73274yNryA9
There was the problem with interferences on screen while calling too. It is gone now .
Bewertung 2
2 Kommentare:
Thank you very much for your solution! I tried everything, and it worked by replacing the conductive rubber (replacement screen as well). I only replaced the small track of conductive rubber on the corner above left - thats the place, where the GPS antenna is.
von
I'm gonna try your solution on my S4. How can I attach the original seal?
What type of glue did you use?
von
Yep, opened it up, everything looks fine. Same deal as Anthony, no GPS and spotty Wifi
Bewertung 1
I replaced the antenna today and no dice, so based on your experience and mine, that's clearly not the issue. Really frustrating as I use my GPS a lot.
Bewertung 1
1 Kommentar:
My fix was very simple. I removed the back-lid and tighten all the visible screws. After this my GPS was up and running. I tried a lot of Apps but none could get more than a couple satellites on board. Any GPS fix or accuracy was non existent and google maps was lagging all the time and putting the map backwards or sideways, missing roads etc.. This happened some time after getting my display replaced for a new one and been driving with a Smartphone holder (which vibrates quite a bit). So i'm guessing the guys at the shop did some sloppy work at tightening the screws and the holder in my car took care of the rest.
Saludos, Uber driver.
von
(fixed)
SCH-i545 Same issue, completed my 5th screen replacement on this phone (the previous 4 replacements completed in years past... I've broken this phone and replaced nearly half of the parts in it.)
I tried everything, I mean every single fix I could find including painstakingly removing the rubber seal on the midframe and replacing it with the one from the previously working screen just like David suggested. I tried to put folded up tinfoil in places to make sure everything was completely connected but in the end the solution was that the GPS spring had been slightly impacted (which I guess is easy to do if you press it with your finger or if the board is installed without everything being aligned properly). I used a thin needle and slid it parallel to the surface of the motherboard to get in-between the spring (not a traditional spring, it's more like a loop in the shape of a shoe/boot) which caused the spring to pop back up. Now it properly connects to the GPS antenna on the inside of the rear frame and all is grand.
  • There are a total of 6 of these springs on the motherboard (4 small, 2 large for wireless charging) make sure all of them are not impacted/smashed down.
GPS Spring
GPS Spring
Cheers is this helps and sorry for the long read and the time wasted if it didn't!
Bewertung 1
1 Kommentar:
holly $@$* this works!!! I would have never thought about this. thank you so much sir. me and my wallet thank you.
von
There are many Galaxy S4 hardware models, just "Galaxy S4" is not clear enough.
I have the service manual for GT-i9500, if you have the correct model i can try to provide troubleshooting.
Bewertung 0
1 Kommentar:
The model is GT-I9505
von
Did you ever get a resolution for this? I'm in exactly the same situation, everything but the !@#$ GPS is working. Any update appreciated.
Dave
Bewertung 0
1 Kommentar:
Hi Dave,
No Answer yet.... did you also open the device up?
von
I have a sch-i545 with the same issue. I replaced the display panel now have no gps fix and weak WIFI. I did a factory reset just to be sure but still no go. Any suggestions?
Bewertung 0
I ordered a new antenna (mine has 2, one white and the other red), so I'll see if that helps
Bewertung 0
I had another working i545 that swapped the two antennas (red and white wires) with and no change. My working phone still had normal GPS WIFI and the one with the replaced screen has no GPS and spotty wifi. I also tried prying up the little gold contacts scattered around the boards that make contact to the case with no change.
Right now I just hope my wife doesn't get lost and needs her GPS.
Bewertung 0
Same problem here (GT-i9505). No GPS and crappy WiFi connection. I reseted it twice, I tighten all the screws, I shouted, I cried and nothing. It's so disappointing, I wanted to wait for the S6 but maybe it's time to change it.
It would be awesome if somebody finds a solution for this problem soon...
Cheers,
Bewertung 0
1 Kommentar:
I opened it completely, tighten hard every screw and it's working again. GPS is perfect but wifi, despite working, it's not as good as before changing the screen...
von
I think you should check where the motherboard interfaces with the plastic mid frame. I think the GPS antennae is in the little plastic cutout just to the left where you see the micro sd label on the mid frame- this has to connect via a spring contact on the motherboard- these spring contacts may be your issue
Bewertung 0
1 Kommentar:
Ok I think I figured out which contact it is (I337 version)- looking from the back its the spring contact in the uppermost left hand side (the one I mentioned above is the wifi contact). Check this one - also its important to make sure the motherboard has a good ground connection so check the contact area where the black screw is
von
I tightened the screw better (the black one inside the phone at the right) and now it's working fine.
Bewertung 0
i have this exact same issue, has anyone found a solution?
i've tried tightening all screws wit no success... unlike some others mentioned here my LTE and my WIFI signals are perfectly fine, just 0 GPS.
Bewertung 0
Downloaded a GPS test app that updated the aGPS data and all is working now.
Bewertung 0
I have s4 i9500. Wifi is working properly but gps is not fixing. The gps testing software show that there are 27 satellites but not fixing and didnot getting the position. I did factory rest on my phone but problem is still exist. Any one please give me some suggestions.
Bewertung 0
1 Kommentar:
Hi..I have the same problem. only gps issue. 15-25 Sat detection..but they lost tracking. Did you get some solution?
von
I got a used i9500, and after installing 5.0.1 Lollipop on it thought that the GPS problems (sees few satellites, and of the ones that it sees can't get a fix) were related to the experimental nature of the 5.0.1 ROM. After reading this thread about tightening the screws, thought - what the heck, can't hurt - tightened all the screws and bang! perfectly working GPS. Unbelievable! Just my 2c for posterity... Thanks, guys!!!
Bewertung 0
Tried everything and $@$*! Nothing works plus memory card is not accepted by my S4 GT 19505!
Now sold it and bought another one for £80 on Ebay!
Bewertung 0
Bewertung 0
I just fixed this problem on my Samsung Galaxy S4. Check for loose screws first and if it does not fix the problem, Follow these steps on this YouTube Video owned and uploaded by outie555:
https://www.youtube.com/watch?v=kMNb8BVr...
Enjoy!!
Bewertung 0
Antwort hinzufügen
AceCrosley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 15
Letzte 30 Tage: 19
Insgesamt: 17,241
