Zum Hauptinhalt wechseln
Veröffentlicht im Juni 2009 / 2.66, 2.8 oder 3.06 GHz Core 2 Duo Prozessor
My MacBook Pro turns on, but has a black screen.
I have done the flashlight test. I shined a flashlight through the Apple logo and can see the login screen. I have reset the PRAM and the SMC to no avail. Not really sure what else to do. Any advice would be greatly appreciated! :D
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 13
19 Kommentare
pr7malone, "the LVDS cable end that plugs into the Logic board looks messed up at the connection." How about posting a couple of pictures and let us see what you see. It is entirely possible that this is your issue.
von
I tried everything, all of the above and then some. I happened to find someone saying "just enter your password on the black screen". Wow! It worked. I'm on a MacBook Pro 2015 running OS Sierra.
von
Awesome guys , I tried reloading operating OSX (at Apple support suggestion) and various system and hardware resets,shift-option-control-power, command-option-p-r.
I was on the phone to Apple support waiting then I came across this (type in your password and hit enter)
and it worked . Many thanks for posting spinaddj
Macbook pro 2011 OSX Sierra sorry MacOS Sierra
von
I tried EVERY hack I could find online. Nothing worked. Then I stumbled on this page and saw the simple suggestion to enter my password again. Voila! You guys saved my life!!
von
Ash, what device and version of software are you using? Mine still does it (goes black) when the batt goes flat and I reboot but the password trick still works.
von
14 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
7 Antworten
Gewählte Lösung
Since this model has a LED-backlit TFT active-matrix display the problem could be the controller or the display. Is there any history you've neglected to share (liquid spill or dropped).
Neither repair is easy, no would I start either one unless I knew it was the correct one.
I'd say take this to Apple, or an Apple Certified Repair shop to find out what is the true problem.
If this answer is acceptable please remember to return and mark it.
War diese Antwort hilfreich?
Bewertung 5
13 Kommentare:
No drop or spill damage. The screen was working and then it just stopped. That's really all I know unfortunately.
von
I know of no DIY procedure for identifying where the problem is for a case like this... maybe one of the other visitors will be able to help.
von
I opened it up and the LVDS cable end that plugs into the Logic board looks messed up at the connection. Could this be the problem possibly?
von
Plug it into an external monitor to help isolate the problem.
von
It works with an external monitor. How do I isolate the problem from there?
von
8 weitere Kommentare anzeigen
Hilfreichste Antwort
EASIEST WAY TO FIX!!!!
The screen isn't black. Its just too dark to see. So grab a flashlight and aim it though the lid where the apple logo is. It will light up the LCD screen enough to see if its on.
Click you user, password and VUALA. welcome back.
And maybe next time don't freak out when your Mac is going slow and stop mashing enter...you shut your Mac down by doing so. YOUR WELCOMES!
Bewertung 14
11 Kommentare:
it really helped
von
Hey... this is not a fix! I can log in but still my screen is almost black. I can only use it flashing a flashlight to it... but it will remain extra dark and wont come on to it's original brighntess although I succesfully logged in...
von
I just used this "ifixit" on a mid-2012 MacBook Pro - used a strong flashlight - took a while to get cursor right, but . then it worked a treat - BUT, what caused the problem, and how do you get out of it without a flashlight ? Would be nice to know !
von
VUALA?? you mean viola?
von
no they mean voila!
von
6 weitere Kommentare anzeigen
Can you see whats on the screen if you shine a flashlight on it when powered on? If so, you need to start with the inverter and/or the inverter cable if one or both look damaged (the cable frayed or cut, the inverter making noise, or burnt part etc), if those don't fix it then you would need to replace the screen.
Bewertung 1
5 Kommentare:
Yes I can see the login screen when I do that. Im assuming the inverter cable is the same as the LVDS cable? I don't know much about Macbooks, but I didn't think my model had an inverter.
von
@Joe Jones, this model does not have an inverter. It uses LED technology to backlight the LCD
von
Regards oldTurkey03!
This same issue is happening to a MacBook Pro 15" Mid-2010 model, I'm thinking on to buy a new LCD/LED screen and replace the original one.
Because the LCD screen is working but without any backlight from the LED... are they one single spare part?
Regards from Costa Rica. tropivan
von
@oldturkey03 I have the same exact problem as this post and I have a macbook pro mid 2012. Do you happen to know if my model does use an inverter or not? I'm trying to find out as much as I can as not te get ripped by the expert who will fix it. If it doesn't use inverter, do you think the LVDS cable could be it? Thanx!
von
@oldturkey03 The cable doesn't look damaged and the connector in the corner looks fine : ( I asked you in another post how to "check" the backlight fuse, I mean, how to tell if it's good or not... And as we are here if you don't mind telling me too where's the BACKLIGHT IC and how to check it? Thanx in advance!
von
I just went through this. Took it to Apple Store genius they did all their tests and found that the hard drive was inoperable.
They would not put a new hard drive in because I had taken it to an authorized Apple repair person and they had replaced the hard drive with a non-apple hard drive.
They had me go to Best Buy and sent instructions for the geek squad to replace the hard drive with a 2.5" SATA drive. I then took my MacBook Pro back to Apple and they placed my operating system in at no charge (apparently apple must send the hard drives they replace back to the apple company for evaluation) since repair person put something else in about 15 months ago that was not the same as the original Apple would not replace it under terms of my apple protection plan).
Lesson learned! Even though it was an authorized Apple repair shop make sure it follows the Apple protection plan and also records the repair work done where apple genius can access it. I went to authorized Apple repair shop because the nearest Apple Store was 100 miles away.
I hope this helps!
Bewertung 0
4 Kommentare:
My Macbook was working fine with the harddrive I had in it for a least a month or two. It is just a Samsung solid state 2.5 HD.
von
Guess I just need to take it up there and see if they can help me.
von
What has a hardrive to do with the screen?
von
Busted cable, anyone?
von
other answers:
Inverter Cable & Inverter Board Location
My MacBook Pro turns on, but has a black screen..
https://discussions.apple.com/thread/402...
https://discussions.apple.com/message/30...
iBook screen switches off/goes black when opened more than 45 degrees
screen backlight not working on MacBook Pro
Bewertung 0
I had same problem and i solved by doing this
https://www.youtube.com/watch?v=7GlETDBy...
Bewertung 0
Like others, I had the black screen out of the blue. I'd tried everything that was posted here, and when my MacBook Pro finally loaded, I got a screen asking me to reset the password. That was not my issue, so I restarted the Mac. Finally, I saw a post that suggested "enter your password ". So I entered my password on the black screen, and THAT WORKED! Thanks so much!
Bewertung 0
Antwort hinzufügen
pr7malone wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 314,109
