Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Repairing broken screen 5s vs 4s?
So I recently repaired a 4s broken screen (screen from ifixit), and now someone else asked me to repair their 5s broken screen. How different are they to repair? If it isnt much different from the 4s I will definitely do it, but I thought I would ask before I say I would will fix it.
Thanks!
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Completly different the 4s you take every thing out then screen is the last thing on a 5s the screen pulls up with a suction cup here is a guideiPhone 5s LCD mit Touchscreen wechseln
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
So would you consider it easier? It sure looks it. Thanks
von
Sorry, you already answered the question while I was writing mine. :-D
von
It's different, but I wouldn't say that it is harder.
The two phones are quite different in their architecture. You already replaced the 4S display so you know that you need to disassemble nearly the whole phone. With the 5S its different here the display is the first thing to unmount. You only need to loose the parts screwed to the front panel like front camera, speaker and Homebutton. (ifixit ships the 5S panel with a new cam installed)
I think if you were comfortable with the 4S fix you should be able to fix the 5S, too. ;-)
Bewertung 1
2 Kommentare:
Wow thanks for the quick replies its really appreciated! Last question, should I buy the $30 suction tool or can I get by with one of the small provided suction cups?
von
The small one works fine and in my opinion sufficient, but the suction tool should be more comfortable.
von
I find it easier but the flex cables for the screen are easily damaged.
To be honest I never use a suction cup cause if glass is cracked it won't lift it..
I use a small pry tool on the bottom left a pry it up
Bewertung 0
1 Kommentar:
Sounds good. I did order the iSclack.......whether it works or not I guess I will find out. I have gotten enough requests from others to repair phones that I just purchased it anyway. Thanks!
von
The only thing I don't like about the Isclack is if your opening a iPhone say for a charging port replacement and the screen adhesive is lifting or lose on the inside the Isclack will rip the glass off the bezel. Resulting in the customer needing a new screen aswel..
Happened to me once and the Isclack went straight in the bin
Bewertung 0
Antwort hinzufügen
nicholashuizinga wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 134
