Zum Hauptinhalt wechseln
Adding Bluetooth 4.0 card to Early 2008 MBP
Hi -- not very technical, but have followed guides here to install SSD on an early 2008 non-unibody MBP. Was wondering if it's at all possible to put something like a BCM94331PCIEBT4CAX bluetooth card into this unit, so that I can activate Continuity/Handoff on Yosemite. I doubt it's possible, and the needed connectors are probably not even in this old laptop, but thought I would ask. Thanks!
Any other advice or methods of getting a bluetooth 4.0 card installed internally on the MBP would be greatly appreciated. Thank you.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Review this: Continuity Activation Tool
War diese Antwort hilfreich?
Bewertung 2
This doesn't seem to answer the question at all.
Bewertung 0
1 Kommentar:
Well it did back in 2014 ;-}
The site has altered things and the info it offered is no longer there.
This series can't support Hand-off Services
von
Antwort hinzufügen
Hiryu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,581
