Zum Hauptinhalt wechseln
Reparatur und Unterstützung für den zur PS3 gehörenden Kontroller. Er kam 2008 heraus, besitzt einen Lithium-Ionen Akku und eine Sechsachsensteuerung. Der Kontroller (CECHZC2) ist leicht zu reparieren.
157 Fragen Alle anzeigen
My Dualshock 3 Controllers mini usb broken and not charging?
My controllers mini usb port has broken and it is not charging ....How do i replace the port ps. i konw how to solder etc and i have an woring port i can replace it with
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I've never replaced the USB on a dual shock before but I have repalced many USB connectors on phones. Shouldn't be any different. Your soldering knowlage should carry you to success.
Before you do any work on it make sure you do your research as well as just looking at how the board and usb are soldered. Disassemble the remote and just take a look at it. Take pictures of the current USB and board for reference. Pre heat the area and make sure you have plenty of flux to keep the heat flowing to the right place.
Good luck on your repair.
War diese Antwort hilfreich?
Bewertung 3
Did you figure out how to do this, because I would like to know how with step by step instructions like you did on the dualshock4 controller.
if you know please email me a pta_red_robin@hotmail.com
Bewertung 0
Antwort hinzufügen
rmeiring wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 4,056
