Zum Hauptinhalt wechseln
Hier handelt es sich um ein großes Smartphone von LG, welches im Herbst 2014 veröffentlicht wurde. Das LG verfügt über ein Quad HD IPS-Display und eine 13-Megapixel-Kamera.
Parts Source: Lens on IR Emitter of LG G3
Does anyone know of a source for a replacement for the little (tiny, miniscule even) lens that covers the IR LED emitter on the top of the G3? I was swapping mid-frames and as I was removing the lens my tweezers got hung up, and when they released, the lens sprung away (never to be seen again).
Everything still works, but the open hole is one more vector that moisture can enter the phone body.
Am I looking at the potentially having to harvest it off of a parts phone?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
Did you find a solution?
von
Einen Kommentar hinzufügen
2 Antworten
The first mid frame I bought came with this, but my second and current frame didn't. As luck would have it (bad luck, that is) for me, the old one crumbled upon removal, and I couldn't locate one online or anywhere. It's a pain, but what I did was, I found an old T.V remote, removed it's lense and carved a new one from it with a hobby knife. (Make sure to lightly heat the tip of the hobby knife. It helps when cutting such a small piece) Then put it in place with super glue. Worked like a charm. Hope this helps.
Update (02/08/2016)
Heat the tip of the hobby knife, not hear. Lol (Thanks again Auto-Correct)
War diese Antwort hilfreich?
Bewertung 0
Hi! Found laser and led covers here: Back Rear Camera Lens Flash Infrared Focus Replair Part For LG G3 D850 D851 D855 RP_LG_G3_DJSGJT
http://s.aliexpress.com/NfuQje2a
(from AliExpress Android)
Bewertung 0
Antwort hinzufügen
Andy McKay wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 576
