Zum Hauptinhalt wechseln
Modell A1502 / 2,4, 2,6, oder 2,8 GHz Dual-Core Intel Prozessor / Erschienen im Oktober 2013
My MacBook Pro speaker is cracking
When I volume up the speaker its has a bit cracking sounds. But I don't sure that it is Left or Right one. But its really a little bit crack if you don't raise it until the limit they won't any cracking sound. How can I check that my speaker are still good or not
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 25
4 Kommentare
Sherri, would a you share how you determined the timeline of programs installed? Are you talking just about program in you application folder or or programs as well.
von
Mine is a 15" macbook pro. I can only fined recommended parts for 13". Can someone please direct me?
von
I am facing the same issue (cracking right speaker) with a MacBook Air M1 chip 2020.
von
Same Problem with my Macbook Pro M1 14" - sometimes speaker makes cracking noise
von
Einen Kommentar hinzufügen
8 Antworten
Gewählte Lösung
Go into the sound control panel and alter the balance setting so you bias one speaker over the other. Then crankup the volume. Which one is it?
War diese Antwort hilfreich?
Bewertung 11
6 Kommentare:
I just wanted to thank you! I never would have thought that going into the sound preferences and changing the alert sound would fix it, but sure enough it did. I play around with audio setups all the time due to music software and didn't think I changed it to the blow sound effect, but I must have. I may have brought it into apple for a repair. It's a desktop so I'm not a fan of moving it anywhere. Thanks again!!!!
von
not worked for me
von
Vijay the tip was so you could figure out which speaker is damaged in its self it won't fix your problem unless you have the volume set to high. Once you know which speaker you can then replace it.
von
Fantastic!! I can't believe it was so easy to fix - thank you. I've been putting up with rubbish sound for about a month now. My right speaker is fine, left is rubbish, so adjusted to be maximum right output, and it now sounds fabulous again. I'm fine with it being lopsided - just needs to sound clear. Thank you so much!
von
I adjusted mine and the awful crack sound is gone. Dalu!!!!
von
1 weiteren Kommentar anzeigen
Hilfreichste Antwort
Check your System preferences/Sounds/Sound Effect tab.
See if there is a sound effects selected, mine was Blow effect, hence the output sounds is crackling.
And I never set this sound effect before, maybe is the original setting from the new OS.
Uncheck the [Play user interface sound effects]
Bewertung 13
9 Kommentare:
This worked for me. Thanks man.
von
I changed from funk to blow and problem gone. Thanks!
von
Uncheck the [Play user interface sound effects] = this help me a lot! just 1 tick!
von
can i know my macbook pro 2013 model, left side speaker sounds cracking . how to solve or off left side spaker
von
not worked for me
von
4 weitere Kommentare anzeigen
Just to add on I had replaced mine old 2010 macbook speakers before, it sounds awful and i opened up to check. the speaker foam has been disintegrated.
If you had tried the above solution by users and the sound is still bad, open up your mac and check
MacBook Pro 13" Retina Display Ende 2013 linken Lautsprecher austauschen
MacBook Pro 13" Retina Display Ende 2013 rechten Lautsprecher austauschen
Some good work around
https://www.youtube.com/watch?v=yJhdMuPo...
MacBook Pro 13" Retina Display Late 2013 Rechter Lautsprecher Bild
Anleitung
Schwierigkeitsgrad:
Mittel
15 - 30 minutes
MacBook Pro 13" Retina Display Late 2013 Linker Lautsprecher Bild
Anleitung
Schwierigkeitsgrad:
Mittel
20 minutes - 2 hours
Bewertung 1
I made a video on how to fix this issue once and for all.
https://www.youtube.com/watch?v=VNd2PgEf...
Bewertung 1
1 Kommentar:
Very Helpful, made me realise which speaker was the problem and saved me a lot of money. Thanks brother!
von
If you’re using a DAW like logic and you have your I/O buffer size any lower than 128 samples and your core audio is enabled then you need to set it to 128 and it’ll fix your problem
go to logic - system preferences - audio - I/O buffer size
Bewertung 1
1 Kommentar:
Worked for me actually at 256, thank you so much, been looking for the answer for months, almost sent my mac for repairs!!
von
Hey guys, I found the fix here https://www.howtogeek.com/670635/how-to-...
I ran the command:
sudo killall coreaudiod
and it helped ?
Bewertung 1
Mine is a 15” and iFixit with some white glue - instead of iReplaceit ;)
Just gave it an hour after applying the glue and is working just fine :D
Bewertung 1
My MacBook Pro (Retina, 13-inch, Early 2015) speaker sound crack on high volume. Is this software problem or hardware issue for which I have to pay for repair.
Bewertung 0
3 Kommentare:
Having the same issues with the 2013 model. Seems to be isolated to the right speaker. At full volume sounds like cracking. Tried resetting SMC and PRAM but nothing.
von
how did u repair it plz suggest me?
von
Same problem but on left side, I think the speaker foam on left side has been damaged, that's why lots of crackling noises on left speaker of my MacBook Pro Mid-2015 Retina display. I just selected system preference - sound - balance (to reduce crackling on left, scroll the pointer on bar to right side and vice versa) but this is just temporary, In my opinion , I need to change the internal speaker,
von
Antwort hinzufügen
shoseipluz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 21
Letzte 30 Tage: 160
Insgesamt: 233,298
