Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Frage geschlossen
What would I have to replace to get my iPhone working again?
So this first part is shameful, but someone threw my iPhone quite hard at a chair that had a thin raised band at the back. It hit that band. The case flew off and when I picked up the phone, it was bent in the middle and would not turn on. I have tried leaving it on the charger all night, safe mode, force reset, plugging it in to my computer ect. The screen isn't broken or anything, the only physical damage is a slight bend, much like you'd get from the bendgate fiasco. Do you guys think some parts got moved around inside from the impact? What's the most likely thing I'd need to replace? The majority of the impact was a third up from the bottom on the left side of the back if that makes sense. If I can't fix it is their a way to get the sd card out and recover my photos? I REALLY don't want to lose my photos. Finally, should I bring it in to apple? Or will they just give me that 323$ replacement thing. Because if I get a replacement I want more than 16 gb storage, that was killing me. Would they allow you to upgrade that for a bigger fee? Do you think it could possible fall under warranty if I lie and say it bent by itself (I am very poor and Apple is a multi billion dollar corporation). Anyways, thank you so much for answering any and all questions.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
That kind of shock, unfortunately, can be detrimental to a logic board. Apple iPhone does not store data on a SD card, and only relies on internal, soldered memory, so unless you have an iTunes backup, there is no way to recover your photos. If you want to keep the same phone, you may have to get a new logic board (iPhone 6 Logic Board ersetzen) and battery (iPhone 6 Akku tauschen). You may want to take it into the Apple Store first. If they say that you need to replace the logic board, then you can decline service and replace it yourself, but this will void your warranty.
iPhone 6 Akku Bild
Anleitung
Schwierigkeitsgrad:
Mittel
30 - 45 minutes
iPhone 6 Logic Board Bild
Anleitung
Schwierigkeitsgrad:
Mittel
30 minutes - 2 hours
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
What would the cost of them repairing the logic board be? Should I be upfront about the accident?
von
Much more expensive than if you did it yourself. Links to the replacement parts are in the guide's "required parts" list at the very top.
von
It is not recommended to replace the logic board, since it does not make economical sense and you'll lose Touch ID and the ability to upgrade/restore iOS forever unless your logic board supplier also includes a matching home button to it.
Go to Apple, as it costs about the same and you get a 100% working refurbished phone
Bewertung 0
1 Kommentar:
Go to Apple to get them to repair it? Or go to trade it in?
von
Send your logic board out for data recovery--your pictures may be able to be saved.
Bewertung 0
1 Kommentar:
Do you have anywhere you recommend sending it?
von
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 137
