Monitor Software for 2005 Apple 30" Monitor
Where do I obtain software for a 2005 Apple 30" Cinema Monitor to operate on Windows 7 64-bit operating system?
Ist dies eine gute Frage?
Apple Cinema Display 30-Inch (Aluminum) Specs
Identifiers: Aluminum - M9179LL/A - A1083
This model uses the industry standard DVI (Digital Video Interface) and requires a Mac or Windows PC equipped with a dual-link DVI port.
You machine may only have a single link video card, see this Wiki on the differences: https://en.wikipedia.org/wiki/Digital_Vi...
War diese Antwort hilfreich?
The user is asking about software.
Depending on the video card, Windows 10, with the proper driver installed for the video card, and with a video card which supports up to 2560x1600 through Dual link DVI cabling, on an Apple 30", can limit you to 1280x800 resolution, and consider that "recommended". Pretty terrible. I think, but am not sure that the issue is the exact driver for my GT1030 fails, with no luck. Since I DO have the dual link DVI cable, it works with the Apple 30" monitors at full resolution with a different video card (GTX780Ti), I think the issue is software, and hence may be similar to what this poster was asking.
So far, no solution. If I clobber the right driver and force Windows to use a generic one briefly, the resolution IMPROVES, ironically.
With a different card, the same computer, LCD, and DVI cable, no problems. But the GT1030 defaults to low res and offers no other options, other than hand-entering custom resolutions, which I am loath to do.
The 30-inch Cinema HD Display just accepts a standard DVI-D connection for video, so there should be no drivers you necessarily need to download. Is there some special function you are trying to do that would require a driver?
I plugged it into my Windows desktop to try a game out at its 2560x1600 resolution, and it worked like any other monitor.
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 8,211
