Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
Are Torx Security bits compatible with non-security bits?
I am looking to upgrade my wife's old Macbook Pro with an SSD, following this guide: MacBook Pro (13 Zoll, Mitte 2010, Unibody) Festplatte Austausch
It says we need a T6 Torx screwdriver. I thought it was weird that the driver kits being sold by iFixIt wouldn't include anything higher than T5 for non-security Torx bits, but then I saw the following on this page: TR6 Torx Security Screwdriver
"Security drilling on this driver makes sure that you won't be stopped by anything, even though this driver still works great in non-security T6 screws as well."
So, can anyone confirm if Torx Security bits are compatible with Torx non-security bits, and does this hold true for all Torx bit sizes?
Precision fixed blade screwdriver engineered by iFixit. Bild
Produkt
$5.99
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 9
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The difference between security torx and standard torx is the hole drilled in the center, this allows the driver to slip over the pin located on the security screws. Otherwise they are identical sizes.
War diese Antwort hilfreich?
Bewertung 5
1 Kommentar:
is just the hole the difference? both share the same sizes?
von
Hilfreichste Antwort
Of course they are, all it is, is an extra hole.
Bewertung 7
Antwort hinzufügen
Help Computer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 36
Insgesamt: 25,218
