Zum Hauptinhalt wechseln
Erschienen im Frühjahr 2014. Ausgestattet mit einem 5,5" Bildschirm. Ursprüngliches Betriebssystem war CyanogenMod 12S. Modellbezeichnung "ONE A0001"
110 Fragen Alle anzeigen
How to get rid of the colour seeping across my phone screen?
It used to be a small spot in the top left corner
I had a green and blue patch at the corner of my phone screen. The colour only shows when the screen is on (the brighter the screen the more visible the colour) and the abnormale colouring did not show up in any screenshots. It looks like water so I put it in rice for a few days. When I took it out it had only gotten worst. The colour has now seeped across the screen and limits visibility. What should I do?
Ist dies eine gute Frage?
Bewertung 5
3 Kommentare
Did the phone actually get wet before the issue started?
von
It may have gotten wet from humidity but it was never in water
von
yup. broken LCD as it is evidenced by the appearance on the right hand top corner. Replace it to repair your display.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
@angelblais without actually seeing your screen and only going by your description, it sounds like a broken LCD. You most likely will have to replace it. Here is the guide for that. Of course, to verify this you can post some images of what your screen looks like with your original question. For that use this guide
iFixit Bild
Anleitung
Bilder zu einer vorhandenen Frage hinzufügen
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
OnePlus One Displayeinheit Bild
Anleitung
OnePlus One Displayeinheit austauschen
Schwierigkeitsgrad:
Mittel
45 minutes
War diese Antwort hilfreich?
Bewertung 4
You may have dropped it recently and it didn't break on the outside bit leaked on the inside
Bewertung 1
I got only blue,black , violent shade on my phone corner
Bewertung 0
Antwort hinzufügen
Angel blais wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 93
Insgesamt: 23,477
