Why is my coffee not hot enough?
Whenever I try to use the Keurig, the coffee doesn't come out hot enough. Please help:(
Ist dies eine gute Frage?
You may have a problem with your water pump. See troubleshooting page.
War diese Antwort hilfreich?
The temperature can also be set on the display via the menu but it is generally a sign that something else isn't working.
Why isn't my coffee hot
If you change it in menu to 192° and it still comes out cold, go to ebay. For 20 bucks you can get a new tank/boiler, usually ships free. Not a fun repair but doable easily once the case is off
There might be three possible reasons if your Keurig is not hot enough
Letzte 24 Stunden: 4
Letzte 7 Tage: 27
Letzte 30 Tage: 103
Insgesamt: 15,444
1 Kommentar
It's not hot when I finish brewing
von Adele Martin
