Zum Hauptinhalt wechseln
A home coffee brewer, released in 2011, manufactured by Keurig. Repair for this device is similar to all other Keurig models.
34 Fragen Alle anzeigen
Why is my coffee not hot enough?
Whenever I try to use the Keurig, the coffee doesn't come out hot enough. Please help:(
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
It's not hot when I finish brewing
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
You may have a problem with your water pump. See troubleshooting page.
War diese Antwort hilfreich?
Bewertung 3
The temperature can also be set on the display via the menu but it is generally a sign that something else isn't working.
Bewertung 1
Why isn't my coffee hot
Bewertung 0
1 Kommentar:
If you change it in menu to 192° and it still comes out cold, go to ebay. For 20 bucks you can get a new tank/boiler, usually ships free. Not a fun repair but doable easily once the case is off
von
There might be three possible reasons if your Keurig is not hot enough
  • There is a problem with the water pump.
  • An issue with the water pump is causing the heating system inside to malfunction.
  • A build-up of dried grounds and calcium clogged Keurig, causing malfunctions.
Bewertung 0
Antwort hinzufügen
Jarred Hall wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 41
Letzte 30 Tage: 211
Insgesamt: 15,112
