Zum Hauptinhalt wechseln
Reparatur- und Demontageanleitungen für Gitarrenverstärker.
knobs crackle and pop
old peavy amp.. knobs crackle and pop
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
FYI - you question is not very good as it leaves a lot unanswered that requires us to guess and ask more questions that we answer. It is like saying "my car runs funny"
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
The pots (potentiometers) are dirty.
1. Get a can of deox it or other electronics cleaner.
2. Unplug amp!
3. Get inside of amp and check on the back side of pots. If there is a small hole
spray some cleaner in there and rotate knob back and forth frpm 0 -10 several times.
If there is no hole, Remove knobs and spray down the shaft in the front give it a minute to get down in there then rotate knob several times. do this to every pot.
4. Put back together and Jam
War diese Antwort hilfreich?
Bewertung 1
Probably needs new pots (potentiometers). If you're not confident changing them yourself, ask at the local music shop - they will almost certainly know someone who you can pay to do this for you.
Alternatively, you could attempt to do it yourself - or just clean them. There are many guides on how to do this, e.g, this one: http://www.instructables.com/id/How-To-C...
Bewertung 0
Antwort hinzufügen
cptnekg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 1,363
