Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Why does iPhone 5 charge to 100% then not work when disconnected?
I suspect the battery, but not sure. It will charge to 100%, but then when disconnected it almost immediately stops working. Erratic. When left overnight without charging, it may or may not have charge remaining. Or, when left unplugged would not work until plugged in, at which point it might show 100% or 40% or whatever.
Also, could signal strength be part of the problem? Severe problem occurs in relatively remote locations or in airplane.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
this is usually signs of a bad battery. it refuses to hold a charge. i would recommend to replace it. The battery run about 20 bucks on amazon and about 10-15 bucks on ebay. When removing the battery be careful with not damaging any other parts of the phone as there are some cables laying under it. i would recommend to watch this video for the full walk through. iPhone 5 Akku tauschen
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Possibly. A lower signal strength means that the phone has to work harder to receive data from the source of the signal. In this case it would be the radio towers if I'm correct.
von
I do agree about what Candido said.
von
The battery can cause so much problems and thats the 1st thing i check,??
Bewertung 2
2 Kommentare:
Thanks, Coco, I went ahead with battery, I confirm your suggestion.
von
My pleasure hope you sort it out
Cheers
von
Antwort hinzufügen
John Lozier wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 121
