Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Can I salvage a missing screw on an iPhone?
Can I use any of the screws from an iPhone 4 to fit the center screw on the panel that supposed to hold down the screen on an iPhone 6? Or does anyone know where I can get a replacement screw because my phone has many problems and I think part of it is linked to that missing screw.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If you mean you're missing the screw in the center of the display cable bracket, sorry to say I doubt that's the source of your problems. In the past I've often put iPhones back together for testing and left that entire bracket off, and everything works fine. (The bracket, as best I can tell, is only there to secure the display cable pop connectors from popping off.) If you aren't convinced, you can try moving either of the two lower screws from that bracket into the center position, as they're the same 1.2 mm length. (Do NOT use a longer screw from the upper area.)
That aside, to answer your question, I don't know about salvaging screws from an iPhone 4—it might be possible, but it would be very easy to accidentally cross-thread the screw if it wasn't a perfect fit. Worse, if you use a screw that's a little too long, you can permanently damage the logic board.
If you're determined to find exactly the right screw, you can purchase a replacement screw set. Finding the right screw can still be tricky though, as they come all mixed together. You can use a digital caliper to check the length, and then visually compare a candidate screw with the other screws on that bracket to make sure it's the right size. Thread it carefully and don't overtighten.
Good luck with your repair.
iPhone 6 and 6 Plus Screw Set Bild
Produkt
$9.99
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Evan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 3,980
