Zum Hauptinhalt wechseln
MacBook Pro Modelle mit 15-Zoll Display
8256 Fragen Alle anzeigen
do you need to apply thermal grease to cpu chips?
Do you need to apply new thermo greese to cpu chips and heat sink rails when replacing logic board? i replaced logic board and everthing works great but just worried i should have applied new thermal greese to cpu chips. thanks
Update
ok no worries thanks for yout help . will def go and do it now.. many thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
No Prob, try Artic Silver 5.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Here is our Generic Thermal Paste Guide, which should help you properly apply thermal paste. Doing it right is very important to avoid overheating issue later in your computer's life cycle.
War diese Antwort hilfreich?
Bewertung 6
1 Kommentar:
+ good
von
Yes, you should have applied thermal paste to the CPU. I always recommend that Posters replace the original Thermal Paste that is on the CPU being that Apple uses cheap thermal paste, and it is usually applied very poorly.
Bewertung 3
2 Kommentare:
+ good
von
+ I use Artic Silver also.
von
many thanks, applied artic sliver as deminstrated in thermal paste guide. works so well sceems to run heaps cooler 2. thanks again
Bewertung 0
Antwort hinzufügen
Kurt Russell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 4,338
