Zum Hauptinhalt wechseln
The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
22 Fragen Alle anzeigen
Is There an alternative to the iOpener
I Dont have an i opener and i was wondering if i could use anything else that does the same exact thing as the iOpener. Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
3 Kommentare
Thanks and also do i absolutely need an iOpener Or anything to do most repairs
von
Here is a video on using a heating pad as an iopener - https://www.youtube.com/watch?v=ZIrmxkX8...
von
https://www.amazon.com/dp/B00AZ72MAE/?th... is a larger option, It may take longer in the Microwave.
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
A heating pad or a heat gun. :)
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
Very, very, very careful use of a heat gun at that!
von
Yea, always use it on low.
von
I know this is a bit late ;>)...
If you are a shop and will be doing iPad repairs on a regular basis, then a heated mat station like this is the preferred solution.
However, if this is for a one-off, the these "Magic Bags" work really well. This one is large enough to cover an entire iPad making it perfect for a digitizer replacement and you can use it at home when you have sore muscles.
Bewertung 4
I used the back of a stoneware plate taken out of the dishwasher after the drying cycle was done. It was quite warm and stayed that way for a long time and did the job fine. Based on previous battery replacement projects, I thought the back of the phone would have to be pried out of attachment fittings on the phone body, but in fact it was mostly held on with glue, so heating and alcohol along with suction as described on this site are the way to go. Also you should purchase the OEM double sticky tape to reassemble the device nicely after the battery replacement.
Bewertung 0
You can follow our guides on using a hair dryer and heat gun, good luck!
Electronics Skills Bild
Anleitung
Wie du mit einem Heißluftgebläse Kleber aufweichst
Schwierigkeitsgrad:
Mittel
Anleitung
Wie man einen Fön zum Aufweichen von Kleber benutzt
Schwierigkeitsgrad:
Mittel
Bewertung 0
Antwort hinzufügen
Zac Cobos wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 34
Letzte 30 Tage: 164
Insgesamt: 8,634
