Zum Hauptinhalt wechseln
Die Xbox One S ist eine Entwicklung von Microsoft. Sie erschien im August 2016 als Neuauflage der Xbox One.
20 Fragen Alle anzeigen
How do I fit a replacement fan?
Hi,
My unit has the widespread 'fan buzz' issue and I want to replace the stock fan with a quiet Corsair model. My question is - how do I fit a new fan into the system? The stock model is designed to fit precisely over the top of the heat sink.
I've read stories of people successfully replacing the fan, so I imagine that it is possible. Would the new fan simply be 'loose'?
Any help will be greatly appreciated!
Andy
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I've been working on this exact problem on my Youtube channel. I've gotten the first part of the video done but still need to do some testing. Here is the link for it.
I've installed a silent wings 3 fan and used an adapter so I don't have to change the wiring. Now I'm just testing to see if the motherboard will make the fan go faster when needed.
War diese Antwort hilfreich?
Bewertung 2
Hilfreichste Antwort
@fantefuturist , Tear down and replace fan assy,(life time warranty) if available links below, contact ifixya to see if correct fan for your unit is available. Good luck.
https://www.ifixit.com/Store/Game-Consol...
Xbox One S Teardown
Bewertung 3
7 Kommentare:
Sorry, perhaps I should've been more clear. I already know how to teardown the unit - I just want to know if it's possible to securely fit an aftermarket fan (that I already own) onto the existing heat sink.
von
Andrew, There is always a way to adapt, it will take ingenuity on your part if mounting differs from your original part. You may have to slot holes on new fan bracket with a dremel type tool or add mounting brackets, use small plastic pull ties, small amount of silicone, etc. Do find a way to secure it, to help avoid noise,vibration and the chance of it floating around damaging other components
von
Thank you for the advice :)
von
Please don't buy that fan linked to above...it's for an Xbox One and not an Xbox One S and won't fit...it's too tall.
von
@tronicsfix , thanks for your input, I made a correction and removed the wrong fan/part.
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
Andrew Makings wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 7,522
