Zum Hauptinhalt wechseln
Eine Digitalkamera, die 2012 von Sony entwickelt und hergestellt wurde. Eine 18,2-Megapixel-Kamera mit WLAN, GPS und einem Speicherkartensteckplatz.
Program Selection Wheel not working properly
Hi,
hope you can help: when I select a program it is often lost. For example: I set the wheel on P but on the screen the selection is - M. I have to move the wheel just a little bit to have the right program set again, but sometimes it's immediately lost again.
Maybe dust under the wheel? How can I clean it?
Thanks,
David
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Now the wheel works (even if ha become a little bit harder to roll), thanks!
Davide
von
David, Glad to here it is working, pretty sure it will start easing up with usage after the cleaning. have a good day.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@catchtherainbow , David, Sony Cyber Shot, remove the battery, squirt a (little) 90% Isopropyl Alcohol under selection wheel and blow out/dry with canned compressed air. Repeat a couple time and this should clean out the dust/dirt from under wheel.
If this does not correct the issue button internal stops are probably worn and button assy. may need replace to correct. I will post a tear down guide if you wish to dig a little deeper into your device.
Sony Cyber-shot DSC-HX20V Gehäuse ersetzen
War diese Antwort hilfreich?
Bewertung 4
Antwort hinzufügen
David wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 15
Letzte 30 Tage: 62
Insgesamt: 1,736
