The charging port broke. Can it be fixed?
Our daughter shoved a random charger into her brothers speaker and broke the port. Can this be fixed?
Ist dies eine gute Frage?
@sharpie75 and @mharrisonline take a look at this guide. Step 6 shows the port soldered onto the board. So it would not be easy. You could try and purchase a broken Bose SoundLink Color and harvest the port from it. Or you could possibly pigtail a separate charging port to it. This will depend on your soldering skills etc. If you can, post some images of the damage (disassembled) with your question. For that use this guide. That would allow us to see what you see and possibly point out where to solder to.
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
Anleitung
Schwierigkeitsgrad:
Schwierig
20 - 30 minutes
War diese Antwort hilfreich?
Within the next week, I am going to bypass the original charging port. And going to pigtail a new usb port.
Just trying to figure out the best procedure. I have over 30 years of repairing pcb components.
I finally got the right tips and opened the case; I need to replace the original port as well, but I am not as experienced as you.
What approach do you suggest? My current idea: melting the plastic with the iron tip until the contacts of the USB port are visible, and then solder a new port/cable on top of that.
Letzten 24 Stunden: 4
Letzten 7 Tage: 59
Letzten 30 Tage: 232
Insgesamt: 17,531
I am looking for an answer to this too.
von Michael Harris
Same thing happened to me. Can it be repaired?
von Darla
I checked online nobody sold a charging port for the Bose sound link color so I called Bose and spoke to them about getting it repaired they told me they don’t repair them he asked me for the serial number off of it and lucky me mine was still under the warranty. I sent mine back they sent me the new model that is out which is the sound link II color. Good luck hoping they will do the same for you. It doesn’t hurt to call them.
von George
think the reason they don’t repair them is because it no longer available it’s a older model if it was a newer model maybe
von George
also checked eBay Thought if I bought a cheap one that was broken I could take the part out it and solder it in mine . but most of them on eBay probably have the same problem . Not worth taking a chance.
von George
2 weitere Kommentare anzeigen
