Zum Hauptinhalt wechseln
Model A1224 / Mitte 2007 und Anfang 2008 / 2, 2.4, oder 2.66 GHz Core 2 Duo Prozessor
548 Fragen Alle anzeigen
Start Up Chime repeats
Hello - My iMac, 20 inch early 2008 won't start up. When the power button is pressed i get the start up chime, the fans turn on, the HD spins then the start up chime sounds again and again in an endless loop.. No video comes on, the keyboard is non responsive. This came upon as a result of over heating I think. Months before this happened the iMac was working sluggish and had frequent freezes.. I opened up the iMac and it had heavy dust clogs on the vents and all inside. Only #1 and #2 LEDs light up..
I have backed up all data on the Drive so the drive is OK.. The memory Chips are fine.. Visually the Motherboard looks fine.. All the tools I have are those for tearing things apart. I cannot test for voltages or any other electronic stuff..
Does anyone have Idea of what part was affected??
Thanks in advance..
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sounds like a GPU failure. I have had a 70% success rate using a hot air flow on the video card, Here's how to get it out: iMac Intel 20" EMC 2133 and 2210 Video Card Replacement
War diese Antwort hilfreich?
Bewertung 5
4 Kommentare:
Oh Great! I was hoping someone with the knowledge like you answered my call.. Very much appreciated. There isn't much on the internet on this topic. The Repeating startup chime I mean.
Can you please elaborate on the Hot Air flow.. I Can do the teardown without a hitch - all thanks to the detailed instructions on this website.
I Take this time to thank all at iFixt.com for the great job. And to the People who take time to answer and share their knowledge with the rest of the world..
Thanks!
von
Thanks Mayer!
von
What is this hot air flow method on the GPU? I have the same issue but many other articles I read mention the MLB - main logic board - as the problem?
von
Mark if you are only going to use it rarely, you can go with a cheap one like this
858D Rework Station Hot Air Gun Kit SMD Iron Soldering Solder Holder Tool New US
https://www.ebay.com/itm/858D-Rework-Sta...
von
Antwort hinzufügen
NPDesigns wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 2,026
