gives flashing question mark icon error
My macbook air (mid 2011 ) gives flashing question mark icon error. (Sorry my bad Eng.)
I got flashing question mark in folder icon error when I want to turn on it and no apple icon appeared (white screen). Then I shut down and press again power button, sometimes it turns on and sometimes it doesnt. For example, it doesnt turn on 30 minutes and I got flashing question error. If it turns on, I can restart and turn on every time– no problem. But if I shut down it normally at OS, cycle start and sometimes it turns on and sometimes it doesnt. I must shut down it because I work freelance sometimes in office sometimes in home.
Also, my battery is dead and my macbook air only works max. 10 minutes with only battery / no charge. And it gave "service the battery" message.
What will be the problem? Can it be wire connection problem or battery problem? I read some blogs that it may be occurred because of wire connection problem. They suggest that open your macbook's screws and control the wire connections.
Note: -I checked the driver error at disk utility , no problem.
Thanks,
Serkan
Ist dies eine gute Frage?
1 Kommentar
I have the same problem. How did you solve yours?
von teotia_aj
